500.6 Miles on one Tank!
Old Jun 8, 2002 | 11:01 PM
adamis's Avatar
Everytime I get the chance to fill my car I always try to beat the most miles on a tank of gas. Usually I only get to a little over 400 before I fill her up again cause I don't want to risk getting stranded. This time however I was taking a long trip and when I returned home I was only 15 miles away from 500 miles. I drove around until finally she gave out just as I was pulling into a gas station. She stopped at 500.6 miles! Now I know it's not the best think to run a car dry but this was to close to 500 not to go for it. Has anyone else gotten this much or more on one tank of gas?
92GXE Auto
Pop Charger
Jacobs Electronics Pro Street ignition
MP3/CD/Soon to be DVD/GPS/7" LCD System (More on this later)
Old Jun 8, 2002 | 11:20 PM
atulb84's Avatar
Re: 500.6 Miles on one Tank!
i got 450ish on my drive to houston, drive around town there, drive back to austin
92GXE Auto
Pop Charger
Old Jun 8, 2002 | 11:50 PM
Nismo87SE's Avatar
Man if you emptied the tank and got 500 miles that is like 28-29mpg. Not bad for a 10 year old car, its funny how nissan did advertise 500 miles on one tank for the 2k-2k1s. Good job.
92GXE Auto
Pop Charger
Old Jun 9, 2002 | 12:02 AM
Tom's Avatar
Tom
Almost
I did 450 miles in one tank once, when I did the Cascade loop in Washington State. 500 miles is definitely doable. I just have to make a case for a long straight road trip to make it happen.
Old Jun 9, 2002 | 01:00 AM
MONTE 01&97 SE's Avatar
Thats great!
Old Jun 9, 2002 | 01:03 AM
ngthing's Avatar
doesn't running a tank dry hurt the cat? i thought i read that somewhere?
Old Jun 9, 2002 | 02:30 PM
Taegost's Avatar
It can damage the injectors
Old Jun 9, 2002 | 03:07 PM
MaxManMo420's Avatar
i got around 430ish one time and thats driving hard on dirt roads
Old Jun 9, 2002 | 03:09 PM
KLoWnPR109's Avatar
jeez, I could probably get 500 around town on two or three tanks
Old Jun 9, 2002 | 03:27 PM
Tom's Avatar
Tom
Cavitation
Running the tank dry can hurt the injectors and the fuel pump by process known as cavitation.
Old Jun 9, 2002 | 05:52 PM
John van de Pol's Avatar
Wow:
I long to see 300 from a tank. I usually get 240-250 when I put my 15.xx gallons in. Has been like this for years.
John
Old Jun 9, 2002 | 10:43 PM
catman316's Avatar
How you get 400 of a tank!!!!!!!!!!!
I usually get like 280 for a tank. BTW a mix betwen highway and city drive
Old Jun 10, 2002 | 06:49 AM
peterkv7's Avatar
I have a 91 SE 5spd. I averaged 27-28mpg on highway driving. I got 400 miles on my tank before the fuel light came on and then I filled up with 14.5 gallons. I was using 89 octane all the way for the trip.
Vince
Old Jun 10, 2002 | 10:02 AM
Lordrandall's Avatar
I got over 30 MPG on 5 freeway, I only stopped to get more gas.
Old Jun 10, 2002 | 10:13 AM
male's Avatar
Re: Cavitation
Not to mantion all the crap settles to the bottom of the tank..run it down like that an all the sediment gets sucked through the pump, filters and injectors. Do this frequently and injector screens get blocked.
Old Jun 10, 2002 | 11:33 AM
kaleb's Avatar
Re: Re: Cavitation
There is no sediment or dirt or anything at the bottom of your tank. If you don't believe me, go pull your fuel sending unit and pump assembly and take a look.
-Kaleb
Old Jun 10, 2002 | 11:09 PM
mykizism's Avatar
Re: Re: Re: Cavitation
-Kaleb
Even if there was sediment or dirt, people are forgetting about the lil device we call FUEL Filters
Old Jun 11, 2002 | 06:48 PM
Pseudopods's Avatar
mileage
I have a 91 SE automatic, and 4 years ago, I drove to Maine (from PA). We stopped for gas at around 350 miles because that's when I figured we'd need to, but my Maxima took less gas than the two other cars in our caravan (a grand am and a jetta... both 4 cylinder). I figured it out, and it was around 30 mpg. I had just had my engine flushed, had new tires (properly inflated), and had polished the car perfectly before the trip, but was still floored that I did better on fuel mileage than the 4 cylinders did!!!
I do attribute a lot of that to the engine flush. I also own a 98 GLE, and had the engine flushed about 10 days ago (trans too). My wife and I just returned to PA from MI, and got 32 MPG from Battle Creek, MI to Youngstown, OH. It was 289 miles and 8.997 gallons of gas (premium).
Also, I believe that keeping your car waxed will help??? Maybe it reduces wind resistance??? Makes bugs easier to get off anyway.
-Seth
Old Jun 11, 2002 | 10:21 PM
getscrill's Avatar
my car only gets like 340-350 miles, how come its so low???
Old Jun 12, 2002 | 08:29 AM
male's Avatar
Re: Re: Re: Re: Cavitation
Explain clogged Fuel injector sceens if that's the case. Fuel filters work, but you can never get it all. You have too much faith in the purity of the gas our beloved petroleum refineries produce.
Old Jun 12, 2002 | 08:52 AM
male's Avatar
And...
Explain why fuel filters get clogged and cause running probs. No dirt in there? Maybe not all cars, but if there isn't, then why have a filter to begin with? We should all take them off and remove the injector screens to allow less restricted fuel flow to the injectors right?
Old Jun 12, 2002 | 08:55 AM
male's Avatar
OK
OK you guys got me..I'm dumb. As someone just pointed out to me, the fuel pickup is at the BOTTOM of the tank anyway. No more arguments.
Old Jun 12, 2002 | 07:58 PM
NightKidsGTR's Avatar
how the hell you guys get 300-500 miles? The highest I ever got was 215...
Old Jun 13, 2002 | 07:01 AM
male's Avatar
How and where do you drive. I get about 300 around town..which is 80% of my driving. I get 350-360 highway, but that's doing 80mph. I guess I could get 400-425 if I drove the speed limit. If you are getting 215 on th ehighway, look into tuneup stuff first, filters, plugs wires, timing, etc. Then check 02 sensor (trips an enigne light I believe, it did on my subaru). If that isn't it, have a shop run an engine diagnostic..they can tell alot from hooking it up to an oscilloscope.
---Mike
Old Jun 13, 2002 | 07:52 AM
Terry28's Avatar
---Mike
i only get around 260 to 300 but not over 300... Maxima rocks!!
Old Jun 13, 2002 | 09:41 AM
Matt93SE's Avatar
STFU n00b!
I get 300-325 per tank cruising on the highway at 115.
O2 sensor will sometimes throw a code, sometimes not. I drove my VG for over 300 miles with NO O2 sensor. i.e. It was removed from my Y pipe and disconnected from my wiring harness. Anyway, it never threw a code and I STILL got over 300 miles on that tank.
Old Jun 13, 2002 | 12:39 PM
Taegost's Avatar
---Mike
My VG gets the best gas mileage at 85MPH
captchaos
Mar 15, 2016 12:18 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
JoshG
51
Sep 21, 2015 10:41 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
hntwhttail
Sep 12, 2015 03:43 PM
