Need VE30DE info from a FSM
I want to compare the valve springs from the VE30DE to the specs listed for the SR20DE. In theory SR20 valve springs/retainers would allow the VE to rev as high as 7500rpm without floating the valves. This means one can get more agressive *topend* performance cams. Also a SR20 intake runners welded onto a VE upper intake collector should be worth another 5-20whp too.
Re: Need VE30DE info from a FSM
any know if the Z valve springs would have the same effect as the SR20s? i know i can get a set w/retainers for like $40..i havent checked on the SR20 prices though..
I will try to find more for you Ari. All I could find in my chiltons, was in the torque specs, says the squareness is 1.059in on the VE. I dont think that will help you much, but I will try and find out some more for you, I appreciate you looking into this for the VE, wouldnt that be great if the VE could use SR20 stuff, it already can use Z stuff, hmmm...best of both worlds
Free height: 45.13mm (1.7768in)
Pressure:
Standard is 535.5N (54.6kg, 120.4lbs) at 26.9mm (1.059in)
Limit is 477.6N (48.7kg, 107.4lbs) at 26.9mm (1.059in)
Out-of-square: Less than 2.0mm (0.079in)
No info on spring diameter.
-Kaleb
Pressure:
-Kaleb
Here is the SR20DE valve spring info:
Free height: 49.36mm (1.9433)
Pressure:
standard is 569.00-641.57N (58.02-65.42kg, 127.93-144.25lb) at 30.0mm (1.181)
Limit is 549.2N (56.0kg, 123.5lb) at 30.0 (1.181).
Out-of-square is 2.2mm.
Pressure:
Pressure:
-Kaleb
Pressure:
-Kaleb
I need someone to post the valve specs
Like the length, head diameter, stem diameter for both intake/exhaust valves.
SR20DE:
head diameter: intake 34.0-34.2mm, exhaust 30.0-30.2
length: intake 101.19-101.61, exhaust 102.11-102.53
stem diameter: intake 5.965-5.980, exhaust 5.945-5.960
SR20DE:
Re: I need someone to post the valve specs
SR20DE:
SR20DE:
length: intake 110.25-110.75mm, exhaust 102.45-102.95mm
stem dia: intake 5.975-5.980mm, exhaust 5.955-5.960mm.
Hmm it might appear that one can use the SR20DE valve springs. The exhaust valves are basically around the same dimentions. WHere as the intake valves are 9mm longer but since the esss areeee twenty valve springs are 4mm longer it should work fine. Now I wonder how they would fit a VG hmmmmmmmm
diameter:
in: 35-35.2mm
ex: 30.5-30.7mm
Length:
in: 110.25-110.75mm
ex: 102.45-102.95mm
Stem diameter
in: 5.975-5.980mm
ex: 5.955-5.960mm
in: 35-35.2mm
ex: 30.5-30.7mm
Length:
in: 110.25-110.75mm
ex: 102.45-102.95mm
Stem diameter
in: 5.975-5.980mm
ex: 5.955-5.960mm
SR20DE:
SR20DE:
Re: Re: I need someone to post the valve specs
Originally posted by Jeff92se
diameter:
in: 35-35.2mm
ex: 30.5-30.7mm
Length:
in: 110.25-110.75mm
ex: 102.45-102.95mm
Stem diameter
in: 5.975-5.980mm
ex: 5.955-5.960mm
diameter:
in: 35-35.2mm
ex: 30.5-30.7mm
Length:
in: 110.25-110.75mm
ex: 102.45-102.95mm
Stem diameter
in: 5.975-5.980mm
ex: 5.955-5.960mm
Hmm I've studied the specs and it appears the SR20DE valve springs/retainers should fit without much drama. Also the exhaust valves for the VE and SR20 are almost the same size. The difference in the intake valve is probably due to the design of the highport head on the SR20. This would be a great mod for anyone removing the heads to fix the VTC. Also an ISKY 260 or 270* grind simular to the VG cams would work great.
Probably great. But it's gotta be hard to make the intake cam when it's varible. If the VE motor is working well, I would fully expect it to make some serious #s due to the varible intake timing and dual stage manifold on the 5-sp versions.
Originally posted by dmontzmax
wow, great info ari. How would it perform with boost?
Re: hmmmm
I have a 160k mile SR20DE in my garage. I think the valve springs/retainers are good. If I ever pull the head the first $50 MO takes them.
Originally posted by MaDMaX024
hmmmm...anyone with some SR20 valve springs they wanna hook me up with? how about a set and a half? :grin:
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
come on guys open up the book and look...Arent you curious to know?
