bad seal on I30 corners?
Well, my clearing project has taken a bad turn. I cleared my tails and all went pretty smooth. That gave me the confidence to clear my corners. I think I should have just left well enough alone. It all went fine untill the next day. Now my corners are all foggy. I know it could be condensation but it really does not seem like it. I did have to use some superglue to hold the new piece in place, maybe some wierd reaction to the fumes?(I know that sounds wierd) There is a thick white substance inside my corners, especially where the new flourecent piece is. Has any one had this problem and what the hell is that white hazy stuff? It seems my seal is not tight and that may be causing it. I don't know?. Is it bad to reopen them again because I would like to reopen my tails to slightly adjust the replacement piece, It moved a little and there is a small 1/8" gap on the side.
The corners look fine untill you get up close. I really wish I would have left them alone. Now I probably just buy some corners unless I can figure out the problem. I will be at a meet tomorrow so I can see if it looks as bad to others as it does to me.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
