Who Subscribes To AllData?
Originally posted by Turbobink
Any one hold this subscription? ...
1999 Maxima SE TSBs
If so, what are the two TSBs for the 1999 Maxima SE all about?
Turbobink: You had the questions, here are your answers. However, in TSB#2, be forewarned that it's missing some pictures and applies to diagnotic tools that normal DIY (like myself) won't have, so it may not be totally complete to us, but at least you can get an idea of what they're talking about in the TSB text. Good luck.
TSB #1 98-042 MAY 98
Automatic Transmission Fluid.
Classification:
AT96-001
Reference:
NTB98-042
Date:
May 15, 1998
AUTOMATIC TRANSMISSION FLUID
This amended version of NTB95-055 updates information regarding the Recommendation ATF usage.
Please disregard previous NTB95-055 and NTB93-065.
SERVICE INFORMATION
IMPORTANT NOTE : Nissan Matic "D" ATF must be used in performing repairs paid by Nissan, such as warranty, service contract, or goodwill repairs. Nissan will not reimburse dealers for repairs when non-genuine Nissan Matic "D" is used.
For current and prior production Nissan vehicles, front wheel and/or rear wheel drive, only Nissan Matic "D", or other ashless petroleum based ATF, is formulated to meet the requirements of Nissan automatic transmissions and automatic transaxles. Nissan Matic "D", or other ashless petroleum based ATF, assists in ensuring transmission durability, smooth driveability, low exhaust emissions and customer satisfaction.
Only an ashless type petroleum based ATF should be used to repair Nissan vehicles because other types of ATF may contain compounds which adversely affect transmission performance. Specifically, ash will impact friction response. In addition, ATF with ash is likely to have a higher Zinc (Zn) content. Zinc will adhere to clutch linings and cause slippage, resulting in transmission damage.
For ordering procedures, please refer to the "Dealer Confidential Parts Price List".
TSB #2 97-028 APR 97
Diag. Prod. For P0731,P0732,P0733 (A/T Signal) With..
Classification:
AT97-001
Reference:
NTB97-028
Date:
April 16, 1997
DIAGNOSTIC PROCEDURE FOR P0731, P0732 & P0733 (A/T
SIGNALS) WITH NO DRIVEABILITY INCIDENTS
APPLIED VEHICLE(S):
1995 & later Maxima (A32)
1995 & later Sentra/2OOSX (B14); SR2O engine only
1997 & later Truck (D21)
1996 & later Pathfinder (R50)
1996 & later 240SX (S14)
1996 & later Altima (U13)
1996 & later Quest (V40)
1996 300ZX (Z32)
APPLIED TRANSMISSION # (S):
Automatic transmission with OBD-II only
SERVICE INFORMATION
If an applied vehicle has a MIL "on" condition with P0731, P0732 or P0733 stored with no driveability (shift shock, slipping, etc.) incidents, use the procedure in this bulletin to diagnose and repair the incident.
These codes can be retrieved only in the ENGINE SYST section of CONSULT. These codes will not be recorded in the A/T SYST section of CONSULT
SERVICE PROCEDURE
Confirmation
1. Connect CONSULT. Confirm the throttle position sensor (TPS) setting is correct as follows:
2. Bring the engine to normal operating temperature.
3. Select A/T, then DATA MONITOR then SELECTION FROM MENU (see Figure 1).
4. Select VHCL/S SE A/T, THRTL POS SEN and ENGINE SPEED.
5. Then select CLOSED THL/SW, GEAR, THROTTLE POSI and VEHICLE SPEED. PRESS ENTER TO SAVE THESE SELECTIONS.
6. Press Settings and select HI SPEED/MANU TRIG. Press START and watch the data.
7. Road test the vehicle. Accelerate to approximately 40 mph. Release the throttle until the CONSULT shows the CLOSED THL/SW is in the "ON" position.
8. Let the vehicle coast and push RECORD on CONSULT (data). When the recording is completed, display the record on CONSULT and look for a voltage increase at the TPS output.
- The TPS voltage with close throttle switch "ON" should be within the service manual specifications (refer to the AT section of the appropriate service manual).
- The TPS voltage should never go above the service manual idle specification when the close throttle switch is "ON".
Root Cause (example - main concern is the TPS voltage)
The automatic transmission control unit (ATCU) uses the TPS voltage to monitor driving conditions (acceleration or deceleration). When the TPS voltage increases above 1.0 volts (with close throttle switch "ON" & vehicle in deceleration) the ATCU goes into diagnostic for A/T signals. If the ATCU does not see an increase in vehicle speed within 3 seconds, an A/T signal DTC will be tripped (see Figure 2, engine speed and throttle position are not shown).
NOTE: Close throttle switch is "ON" the entire time.
NOTES :
1. Throttle is "OFF" (close throttle switch is "ON").
2. TPS voltage is increasing (ATCU thinks the vehicle is accelerating); but the vehicle speed is actually decreasing.
Repair
1. If you can duplicate the MIL "on" incident with the Confirmation procedure, replace the IPS to resolve the incident.
2. You must adjust the IPS after installation. Refer to the EC section under Basic Inspection in the appropriate service manual.
3. After the TPS adjustment, you must re-set the idle position memory. Refer to the EC section under Basic Inspection, RESET IDLE POSITION MEMORY in the appropriate service manual.
4. After resetting the idle position, verify the engine RPM at idle.
5. After step 4, you must check the IPS output voltage at idle. Make sure there is no duplication of the same incident.
6. Perform the Confirmation procedure again.
PARTS INFORMATION
CLAIMS INFORMATION
When applicable, normal claims coding applies.
bobcat
Mar 15, 2011 11:10 AM
davey6693
Apr 23, 2004 11:09 AM
ms.thicknes
Sep 13, 2002 04:16 PM
