Pictures from my brake install
I installed my Stillen FSTB and Sway bar earlier in the week and yesterday I installed my Stillen/AP Racing Brakes.
The install took about 5 hours which included the front kit rear pads and SS Lines and ofcourse a full bleed of the system.
The kit install was easy but rear pads were a pain, I did not know I needed a special tool to turn the pistons back in. The dealer was closed so my friend made his own tool and was able to finish the job.
I still haven't used the brakes too hard because I am breaking them in, I'll have a chance to REALLY test them out as I am going to Shannonville tomorrow for a lapping day.
But to give you an idea, the pedal feel improved alot but some improvement can still be had. The fronts are squealing a little under light breaking, I hope it eventually goes away.
I went for a little run today and while I didn't jump on them I did use them to slow down quicker then I was. You can definately feel them "bite" harder and the amount of force I have to apply is so much less then before, can't wait until they are broken in.
I wouldn't reccomened these for someone just using them on the street, just not worth it. Go buy the SS Lines, Fluid, pads and X Drilled rotors. However if you plan on doing lapping days then these are a must to fully enjoy your car.
Pictures are here
http://members.rogers.com/maxrpm/parts.htm
Pictures are here
Re: Pictures from my brake install
Your wheels are nice.
Re: Re: Pictures from my brake install
Originally posted by GimmeTorq
What kind of tool is this? Are you talking about a C-clamp or something more sophisticated?
Re: Re: Re: Pictures from my brake install
Not a C Clamp, tried that, the piston "turns" in so a special tool is needed from Nissan.
Post a price..
.. my next mod after my 19's which will be in soon, will be that ! I just need to know whether to go all out and get a full brake kit, or just X drilled Rotors with Pads... I only do street driving, and god forbid racing !
kloogy, I don't think you can get a set of aftermarket X drilled rotors and pads for your 2K2 yet cause no one has made them. But for about $500 - $600, the 300ZX TT's calipers and rotors might be a good upgrade for your 2K2.
i hate the gold ones.
there is a group deal going on....all 4 rotors for 200 bucks(X-drilled/sloted)
http://forums.maxima.org/showthread....hreadid=132164
Originally posted by krazyd
Are those just the Stillen Cross-Drilled Rotors from EatRiceZone.com? I'm very interested in putting those on my 2001, but I was wondering if they're really worth the $$$?
Nice, wish I would afford do these. But since you say it really dont help much on street driving, that makes me feel much better.
Dixit
http://members.rogers.com/maxrpm/parts.htm [/B]
I made the mistake of forgetting this when I did mine, and the squeal only got worse. I disassembled them and applied the compound, and all is good. It comes in a little packet from you local autoparts store ($1).
Did you read the break-in procedure for the rotors? It's very specific about going easy on the rotors for about 300 Miles to properly break them in. The stillen rotors recomend this process you're supposed to 10-12 times (it's like a moderate stop from 30 MPH, and then no highway speed stops for a few hundred miles), or something. Go easy on your new setup!!
Pics look great! Nice Job
I can't wait until we get the cross-drilled\slotted rotors in the group deal, but I'm curious what color will show once the nice silver finish wears off.
dank4us
34
Jun 10, 2024 03:45 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
