Installed my heater and pressure gauge
both from dynotune, well I ran my car around last night and the pressure never got over 704 but was still rising, it started out at like 566 or so, I adjusted the sensor twice but it seemed to take forever. The bottle felt very very hot to the touch when I got home and the pressure was at 704 any thoughts? Does it take like an hour to get up around 1050 or what?
Something's wrong if the bottle feels hot to the touch. Usually the bottle is warm, like a fevered forehead, when pressure is around 1100 psi. You really should have a bottle blowout installed....
Be very cautious - an overheated bottle can rupture and blow off the back of your car. Get another pressure gauge if you can, just to crosscheck the bottle pressure.
the heater is controlled by a pressure sensor that is hooked to the relay, the gauge is not controlled by anything just reads pressure at the same point that the heater sensor is located, it reads pressure all the time but the funny thing is when I went out yesterday the pressure in the lines was -004? I wonder if the gauge is off by 4 lbs pressure? when I turn on the bottle it jumps to mid 500's, its about 30 deg. outside so its kinda cold here in CO. I do have another pressure gauge NX dial type so ill check to see if there is a difference, that was a great idea I didnt even think about it
The bottle can be warmed with a 500 watt quartz light, outside of the car. Just shine it on the bottle until the small end of the bottle is warm to the touch. Betcha you then have about 1100 psi showing.
I do this all the time when warming a bottle before going to the strip on a cold morning. I then wrap the bottle in a blanket until I'm ready to connect the bottle at the track and wrap it in the heater pad. Just warm to the touch is always enough for me....
update: I installed the mechanical gauge a little hard to read but it showed about the same pressure as the digital one when I opened the bottle... I guess I will hope nothing is abnormal, I thought all NX bottles had a pressure burst thing for safety its black plastic on the opposite side of the nipple points directly up? I ripped an email to dynotune so ill see what they say.
All NX parts can be found here: http://nitrousdirect.com/nitrous-express.html
This might give you a good idea of how many options they have.
Originally Posted by Maximaaa
Is the bottle full? If the level is down the pressure wont be as high..
Dont mean to ask a stupid question..
Maybe you have less nitrous than you think?
Originally Posted by vq356sp
I was about to ask the same thing!
ah yes this crossed my mind also and I dont know how much is in it, ive run around the streets and used it maybe 10 times or so, not more than 5-8 seconds so im guessing it could be pretty low, I dont know what the weight is with the bottle opener on it so I was just going to open the valve let all the nitrous out then weigh it to get the exact weight, then of course go fill it again.. ive been snowed in for a few weeks so the car hasnt seen daylight 3 weeks, waiting waiting waiting
Originally Posted by babymac
Don't most bottle heaters turn off themselves when they reach a certain temp.?
I know my zex heater has a built in thermostat and shuts off when a certain temp is reached.
The pressure switch actually controls the heater relay, and the bottle valve has to be open before you enable the heater. Otherwise, you can blow the bottle or popoff disc.
lowpost99
05-16-2021 11:18 AM
MaxLife17
06-27-2019 01:37 PM
jds22
09-04-2015 01:52 PM
