Ways to prevent the car from not starting because of the cold weather?
Old Jan 14, 2004 | 11:56 AM
amixam98's Avatar
Needs non-Maxima Friends
Hearing alot of my friends are having a hard time starting up their car because of the cold weather up here. Any ideas to prevent this from happening?
Old Jan 14, 2004 | 12:09 PM
2k2kev's Avatar
It's chrome alright...
keep the battery in good shape, park it in a garage, make sure the plugs are not fouled, I read somewhere you shouldn't park a car in this kind of weather for any extended periods unless it has more than 1/2 tank (not sure why, might be an old "dad fable")
Old Jan 14, 2004 | 12:11 PM
MaxPerformanceSE's Avatar
Yours friends could buy a battery warmer or get an Optima Red Top.
Old Jan 14, 2004 | 01:31 PM
Ant96GLE's Avatar
Any buildup on condensation will turn into ice.. and you sure dont want that in your fuel lines
Old Jan 14, 2004 | 02:00 PM
hurleybob's Avatar
One word, "engine block heater". Well 3 words. Was -4 F. at my house in NY this am.
Anyone know a good mod on the org for adding one? (wish I could search) OEM preferably but aftermarket would be too.
Old Jan 14, 2004 | 02:17 PM
hurleybob's Avatar
The problem with lots of air in the tank is that air contain water. When that air and the tank itself become 2 different temps due to changes in weather the result is condensation. Not a big deal in summer, but in winter that could mean ice in your lines.
Old Jan 14, 2004 | 03:03 PM
Stealth Max's Avatar
Tell your friend to try a bottle of dry gas for the gas tank. Run the car everyday for a few minutes especially when you don't drive it. Make sure the battery is in good shape and no corrosion on the contacts. The cold kills the battery and make it has less effective with the cold cranking power. Hope the infos from others and here helps your friends out.
Old Jan 14, 2004 | 03:25 PM
happyricefob's Avatar
V^___^V
turn off AC and any 12V devices at start up so your alternator won't overwork.
Old Jan 14, 2004 | 03:31 PM
Jaws's Avatar
Buy some gasline antifreeze (aka methyl hydrate), dump it in the tank and you won't have frozen gas lines.
Old Jan 14, 2004 | 03:35 PM
MrGone's Avatar
the hamsters are frozen or very very cold poor little guys.
Check the battery voltage, if it's fine, I recommend upgrading to a battery with more CCA's (cold cranking amps).
Old Jan 15, 2004 | 12:56 AM
wariow's Avatar
start the car at least once every 24 hours and let it warm up. Give it a good rev before turning off the car to quickly rejuvy the battery.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
