Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Supercharged/Turbocharged (https://maxima.org/forums/supercharged-turbocharged-38/)
-   -   flow ? of 370's (https://maxima.org/forums/supercharged-turbocharged/233637-flow-370s.html)
cardana24 Jun 7, 2004 09:15 AM
flow ? of 370's
I sent my 370's off to RC engineering to have them cleaned/new caps and o-rings put in before the install. When I got them back they came with a sheet to show how each one tested before and after the service. The average flow was 410cc, some a little more some a little less. In there comment field they put that this was "excellent" for these injectors. My question is, is this common for the 370's to flow like this? I was under the impression that 370cc would be the highest point they would reach. These injectors are out of a 95 TT Z. Thanks.
Carson
mtcookson Jun 7, 2004 10:23 AM
it probably depends on the pressure they were tested at. if i remember correctly most flow rates are rated at 43 psi and if they had the pressure higher than that it would flow higher than 370. i could be wrong though but i'm pretty sure that's what i read somewhere.
pawnstar12 Jun 30, 2004 08:00 PM
mine were done at rc and they flowed 350 to 365
Bags Jul 1, 2004 07:29 AM
mine were done at rc and they were ~405
95zTT .. green color
