fuel pressure gauge
fuel pressure gauge
I just installed an adjustable fmu and will also be installing a fuel pressure gauge. I just needed to know off what fuel line do I need to put the gauge on before or after the fmu?after the fuel pump? its just a T fitting that taps in the fuel line the gauge will also be under the hood just to tune the fmu. thanks in advance
Originally Posted by I30tMikeD
The fuel pressure gauge goes right after the fuel filter, before the fuel rail. The FMU is on the return line.
Again... you want the gauge after the pumps, and before the FMU/FPR (so, before the fuel rail)
Originally Posted by NvDakid
anybody have any pics to show us better thanks
tank--->pump--->filter---->gauge--->rail--->injectors--->pressure regulator--->return line---->tank
your gauge should be before the rail.
Originally Posted by hlh0501
be careful with "right after the fuel filter" if his inline pump is underhood.
This is a really bad pic, but it shows you what you need. The fuel pressure sensor taped into the fuel line with a T-fitting right after the fuel filter. Mine is electric not mechanical
http://img.photobucket.com/albums/v1...d/112_1286.jpg
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
