NGK Iridium IX part number? BKR7EIX-11 I'm assuming?
Old Mar 29, 2005 | 10:30 PM
Nealoc187's Avatar
SLOW
EDIT: went ahead and ordered the BKR7EIX from sparkplugs.com instead and got two day shipping so i can have them before this weekend when i hopefully will dyno. any suggestions on how I should gap them, since the spark is so much better than copper under high cylinder pressure conditions (that throws my current gap out the window most likely) or just start out big (like .040) and start dropping the gap if I start to have problems? this will be without KB Boost-A-Spark for now until after I get this trans built btw.
Just wondering if anyone has any other opinions on this. I'm trying to buy some NGK Iridiums on ebay right now, and since the proper copper PN for our car is BKR5E-11 (or 7E-11 in my case) I am going to assume that BKR7EIX-11 is what I'm going to want? They have BKR5EIX-11 listed for most nissans, and then a bunch of other funky part numbers that don't look anything like our part numbers for other cars.
Old Mar 30, 2005 | 08:52 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i would think that .038 would be a better starting place than .040
where are they gapped to right now? less than .03x?
Old Mar 30, 2005 | 09:05 AM
stephenlc's Avatar
didn't mardi get 2 step colder platniums?
Old Mar 31, 2005 | 10:08 AM
Stephen Max's Avatar
How much boost are you running, Neal?
Old Mar 31, 2005 | 01:17 PM
Nealoc187's Avatar
SLOW
right now I've got 2 step colder coppers, gapped to .032 if my memory serves me correctly. I'm running 14.5psi right now, cranking it up to 16ish is likely in the next month or two. probably no higher than that without my own WBO2 or J&S or race gas.
Old Mar 31, 2005 | 01:33 PM
Royal_T's Avatar
Nealoc187,
So what is the part # for 2 step colder plugs. I need to order some.
Old Mar 31, 2005 | 02:08 PM
Nealoc187's Avatar
SLOW
For 2 step colder coppers its bkr7e (the -11 on the end just tells what the gap is, which you can change yourself), for 2 step colder iridiums its bkr7eix.
Old Mar 31, 2005 | 04:19 PM
Royal_T's Avatar
http://sparkplugs.com/more_info.asp?AAIA=&pid=15057
I just want to make sure these are the right ones right?
Old Apr 1, 2005 | 06:32 AM
Nealoc187's Avatar
SLOW
Those are the ones I ordered. I don't know if those are the correct ones that's why I posted the question. Common sense tells me they are the right ones but no one who's using them has said for sure. I guess if my motor blows me to the moon I will know they are the wrong ones, but I suspect they are the correct ones.
MAXSE5SPD
Sep 17, 2022 04:00 AM
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
