Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Supercharged/Turbocharged (https://maxima.org/forums/supercharged-turbocharged-38/)
-   -   5th gen muffler beneficial on SC'ed Max? (https://maxima.org/forums/supercharged-turbocharged/295949-5th-gen-muffler-beneficial-sced-max.html)
BlackCat Apr 11, 2005 11:40 AM
Would it be beneficial have one? I'm considering putting on the 5th gen muffler. Other than cutting the bumper to fit the dual tips I understand that the piping has to be cut to fit the b pipe and a new flange welded on.
Stephen Max Apr 11, 2005 11:58 AM
It probably is beneficial, but I haven't seen any comparison between the 4th gen and 5th gen mufflers. The 4th gen muffler is pretty restrictive. For instance, I measured 17 psi of backpressure at 11 psi boost with my oem muffler, and only 10 psi with an Apexi WS muffler.
slimer Apr 11, 2005 12:01 PM
i heard that the 5th gen muffler has a dual chamber to decrease backpressure.
there is a cutaway picture somewhere out there. i remember seeing it in Nissan's promotional material.
1FSTMAX Apr 11, 2005 12:07 PM
For NA application the 2k muffler would be fine. But for Boosted apps, I don't think it would flow pretty well. I belive the exhaust tips are like .94", so they wouldn't flow very well under boost.
Jeff92se Apr 11, 2005 12:20 PM
Mr. Yamato sig. :) I understand the want for a quiet free flowing muffler for your sc max. But the inlet of the y2k muffler is only about 2.25 or so. I don't know if the outlet size really matters more/less than the inlet size. I have a Y2k on my na maxima. I love it. It's super quiet. It's design IS supposed to give quiet sounds at the low rpm range and good flow at the higher rpm range. (ie.. flapper that opens). But I don't know if these will help a sc max. Or I should say "I don't how much it will HURT your performance over what you have now".
I've seen more than one post about guys getting some pretty good hp increases by upping the catback pipes over 2.5"(sc maximas). So I'll say that the Y2k muffler won't really net you much. But as said above, it might not HURT you that much over what you already have. Unless your current exhaust pipes are 2.5" or larger.
Bags Apr 11, 2005 12:25 PM
your sig is to big, fix it
Bags Apr 11, 2005 12:27 PM
http://forums.maxima.org/showthread....hlight=5th+gen
NA, but expect similar results over an aftermarket muffler:)
BlackCat Apr 11, 2005 01:00 PM
Yes Mr. Jeff :) Glad to see you know where I got the sig!
I'm at 2.5" right up to the point where the b pipe meets the stock 2.25" muffler pipe. I do notice the power difference everytime I put on my straight-through muffler but the experience only lasts for a week and I put the stock muffler back on before my ears bled. When I had the stock b pipe I couldn't feel the power difference but I sure did get the extra sound effect.
After reading about the baffle within the 5th gen muffler I thought that it would benefit the SC breathing at higher speeds.
Jeff92se Apr 11, 2005 01:03 PM
Well I think you could get a shop to put an hydraulic expander on the opening to get it to 2.5". For how cheap these mufflers are now, it might be worth a try. It WILL be quiet. I pretty sure you will like the sound. But performance-wise, I don't know. Should be better than a stock 4-gen muffler. But don't know if it's better than those loud straight though types.
Larrio Motors Apr 11, 2005 02:54 PM
restricting the very end of your exhaust would not be a good idea with a boosted application. But I guess you could hook up a electric cut off to reduce noise when you want to
Jeff92se Apr 11, 2005 02:55 PM
larry. I don't know what would be worse though. For one he already has a small 2.5" catback. I would think if you have to restrict one side, the end would be better?
Larrio Motors Apr 11, 2005 07:35 PM
I guess so, but its still hard to say. I guess it would also be dependent on the amount of boost blackcat is running.
Isn't the stock manifolds like 2.25 inch in diameter and the only part that becomes 2.5inch on a y-pipe is after the pipes converge? In that sense there is already a restriction at the beginning and now with the 5th gen muffler there will be another at the end.
1FSTMAX Apr 11, 2005 09:17 PM
Black cat just get a RS*R EX mag muffler, with two resonators, and your exhaust should be pretty damn quiet.
chris'smax Apr 12, 2005 05:27 AM
I am running the 2k muffler right now and i deffinetly noticed a power loss in upper rpm's. I switched from a straight through muffler becasue the sound was really starting to get to me. To me the 5th gen muffler sounds incredible when at WOT, but again you do loose some top end. To solve that problem i am going with the ATP boost actuated cuttout. That ought to be free flowing enough :chebosto: . I say if your not out to muster every last pony out of your car then go with the 5th gen muffler. Hope this helps with your decision Blackcat
JAY25 Apr 12, 2005 06:02 AM
stock pulley it should be okay, on top end it will kill you because of the bad flow. Personally if your ears bleed Id get a cut out so it opens up after 5 PSI. I am definitely thinking of going that route.
Jaime
Jeff92se Apr 12, 2005 10:29 AM
Yes. But each 2.25" manifold is only handling 3 cylinders.
Larrio Apr 12, 2005 11:28 AM
ah, i see. It would be worth it to have a litte loss on the top end for a overall quiet drive
IceY2K1 Apr 12, 2005 03:37 PM
Sounds like you liked chris'max VES boost activated cutout?
Jaime
Nismo87SE Apr 12, 2005 04:22 PM
I have a dyno on my se-r comparing an open 3in cutout before the muffler vs running through a 2000 max muffler. Now my car is NA with bolt ons, here is the dyno. The first run is with the cutout capped and the last 2 are with it open.
Jeff92se Apr 12, 2005 04:28 PM
No hot linking Ari
Nismo87SE Apr 14, 2005 05:55 PM
Originally Posted by Jeff92se
No hot linking Ari
Try this link and see if it shows
dyno
