brake booster check valve question
my search funtion is down right now for some reason so i dont know if this is a dumb question but i was wondering if i need a check valve for the power brake booster? i dont want to pressurize the unit for a few reasons
1. power brake failure 2. damaging the seals in the booster or master cylinder 3. loosing boost pressure and hp do the tt 300z have one we can use? |
iirc the brake booster has a check valve. Someone correct me if im wrong!
It has a check valve. Just connect it to the manifold and your set
-matt |
thanks!!!!!!
IIRC some one had a problem with boost leaking into the booster. They used 2 from a turbo supra and that solved the problem.
~Alex |
MikeD had this problem - when going to the brake immediately after being in boost at the track = no brakes. Replaced the check valve, problem went away.
Nope, your wrong. Problem was never fixed |
Oh I thought you replaced that check valve.
Originally Posted by matty
(Post 4481757)
-matt |
Originally Posted by Jennifer Daugherty
(Post 9203654)
Where is the brake booster check valve at? I can't find it around the manifold, and I'm totally stumped!!!! I nade a new thread about this issue just incase. Any help is apprechiated!!! Tia!!!!
Follow your brake booster tubing it's in the middle-ish |
Originally Posted by Fakie J Farkerton
(Post 9203719)
It has an arrow on it
© 2024 MH Sub I, LLC dba Internet Brands
