Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Supercharged/Turbocharged (https://maxima.org/forums/supercharged-turbocharged-38/)
-   -   Car won't rev over 2000rpms (https://maxima.org/forums/supercharged-turbocharged/555163-car-wont-rev-over-2000rpms.html)
akurtzer57 Feb 29, 2008 11:08 AM
Car starts just fine but when I give it gas it is responsive but its 2000rpms and its like its got a rev limiter? I double checked everything is plugged in correctly and all vaccum lines. Looked at SAFCII and knock sensor was at 0 at idle. Put a timing light on the car and it won't show the marks. Have to advance the gun to 65 before the marks are on the pointer. Car is in time and idles smooth but a little high 1200rpms or so. Any Ideas what needs changed. I believe its just needs tuned right.
98MaXeDouT Feb 29, 2008 11:20 AM
MAF
nismology Feb 29, 2008 11:22 AM
How do you know the motor is still in time?
akurtzer57 Feb 29, 2008 11:24 AM
I guess I can try it weird it just all of a sudden went out. I'll also double check on my wiring for the safcII to it.
well lets see when put new motor in replaced timing belt. Have #1 at top dead center and the red marks all line up on the cams and the rotor on the dizzy pointing straight at #1 thats how I know.
nismology Feb 29, 2008 11:36 AM
The timing light seems to disagree with you though...
nismology Feb 29, 2008 11:40 AM
In any case, per the VG section of the FSM, an improper MAF signal for the driving condition will result in a rev-limit @ 2000 RPM like was already mentioned.
akurtzer57 Feb 29, 2008 12:35 PM
Don't got a FSM but thanks for that but just to bad I sold my extra MAF sensor! Sounds like the problem.
fawad Feb 29, 2008 01:45 PM
I just had the same exact thing with a 2001 Maxima. Just replaced the MAF and it worked perfect. Check the signal and go from there and I say 99% its the MAF.
akurtzer57 Mar 1, 2008 01:47 PM
Just tried a different MAF of another running car and it didn't work still like its got a rev limiter at 2000prms.
BenStoked Mar 1, 2008 05:21 PM
Fix timing first...
akurtzer57 Mar 4, 2008 08:18 PM
I have not had any time to work on my car because of work but was wondering today if possibly the crank angle sensor could cause something like this I believe I remember it was in the dizzy itself. Correct me if im wrong.
akurtzer57 Mar 20, 2008 08:09 PM
I know its been a while since I made this post but wanted to let you all know what caused this. I had a broken exhaust stud in the rear and was fixing it when I moved the Oil sending unit wire (I believe thats what it is) the wire completely came off. Fixed the wire and problem was solved. I don't know if it told the ecu there was no oil pressure and it wouldn't let it rev as a saftey issue or what but there was no oil light on and the bulb is not burned out.
jordandalley Mar 21, 2008 01:02 AM
Interesting. Never heard of this before. Thanks for the heads up ;)
Alex_V Mar 22, 2008 05:53 PM
Ah I remember Columbianmax saying something about that on his car. He has a VG auto no power mods and fixing it gave him a smoother idle and seemingly more low end power. Strange your car was limited to 2K and his wasn't...
~Alex
akurtzer57 Mar 23, 2008 05:53 AM
~Alex
well once in a great while it wasn't. It would rev to whatever but 98% of the time it wouldn't.
