vq30dek supercharged need help!!!
ok here it goes.
i have a 98 maxima with a vq30de-k and a v2 charger.
i recently installed a 13psi pulley and got some 510cc fuel injectors.
i also installed a z32 maf.
im using a vafc2 to tune
now i need helpon the base tunning before i go out and actually get it dyno tuned.
i know that for the z32 maf the in and out is set to in-2 and out-4.
i need to know what else i need to change for the fuel difference with my setup.
thanks for all the help
Doubt anyone is going to be able to give you any useful information, you need a wideband o2 sensor to be able to know what setting and corrections you need. In other words, you cant have someone elses tune/corrections on your car, because every car is different. If you dont have a wideband o2 sensor or anyway to monitor it, go to a dyno, and tune your part throttle and then little by little go into WOT, and check the a/f.
thanks for the reply i figured i couldnt get an exact answer of use someone elses tune. i do have a wideband in the car. what i really should of said was can i get some pointers on getting it to run so i can drive it to the dyno without having any problem with lean misses or any detonation.
You have a wideband so why can't you just monitor your afr while driving around? I'm having a hard time understanding what you're asking. They told you that you can't ask someone else for what tune settings to use. You said you understood that. Then you went ahead and asked for it again, just worded differently?
Use the wideband to see what areas you need to adjust. That is the whole point of a wideband. Go drive around and keep the afr under 12.4 when WOT IIRC...
Anything below is rich but better to be rich then too lean.
I have 550cc injectors, but I also have a JWT ecu programmed for the 550cc injectors, z32 maf, 50 psi fuel pressure, etc
Not sure if my car is unique, but it runs best with the safc set for the a32 maf. When I used the settings for the z32 maf it didn't run as well. (yes I have a z32 maf).
KabirUTA13
19
10-17-2015 02:15 AM
