Streetz Dyno (Low boost)
Ok so I just decided to finally dyno for yall to stop whining LOL, j/k. Anyway I went on 11psi however on dyno it showed as 10psi since theres less load (Dynojet). For those that dont know, built block 3.5, HX40 rear mount, Water/Meth injection, and stock timing.
The car has been misfiring for a few weeks, I have not been able to figure it out till today, this morning before dyno i regapped plugs down to .030 from 035, and still missing. Still dyno'ed, and result was 380whp 366wtq, STD. Not happy but considering the crazy missing, auto, and only 10psi on a 8.8:1 compression, I dont think its too bad. So I just went to autozone, alternator is putting out only 35amp, supposed to be 125+, that can def explain the misfire. http://i218.photobucket.com/albums/c...end/380whp.jpg I have it as MPH because in RPM the curve is all over the place cuz of the missing. |
you have stock redline? and its really good for 10-11psi on 8.8:1 pistons. and why did you go .030 i think that gap was too close .035 is prob much better
Originally Posted by TurboA32
(Post 7696883)
thats a 3rd gear pull? and whats your redline?
I have stock redline
so do you think your alternator is on its way out?
(Post 7696917)
You dont read much, huh? |
Originally Posted by bigleman
(Post 7696918)
"alternator is putting out only 35amp, supposed to be 125+"
Agreed 380fwhp is not bad for 10psi on a 8:8-1 motor not get the alt fix and turn the boost up to atleast 15psi where it should be
10psi is for stock motors with stock cr |
Originally Posted by t6378tp
(Post 7697036)
Nice. What was your highest dyno before this one?
Originally Posted by ajcool2
(Post 7697264)
So whats next another trip to the dyno or is it off to the track, personally it would bug me to death being so close to 400hp not to go back
btw do you have slicks or dr's |
I'm going back with no muffler, and 17psi. Taking muffler off alone raises boost like 3psi. I got full slicks
(Post 7697596)
GREAT:)
Originally Posted by streetzlegend
(Post 7697613)
(Post 7697901)
What kind of muffler is that :eek:
the graph looks like a SC, is that the case?
Originally Posted by QT1 5MT AE
(Post 7697975)
I just floored it on my way home and i didnt feel any misfires, now with new alternator!!! going to give it a few more days to make sure it really isnt misssing.
(Post 7697901)
I call :bs:
Originally Posted by Conrad283
(Post 7698085)
I call :bs:
On having a car :nervous:
(Post 7698025)
God no lol. It does look like SC. but the turbo is pretty big so it takes long to spool up, hence the late torque curve.
I'd say 380whp is pretty good power for 10lbs.
Anything done to the auto to hold the power? |
Nice numbers, easily looks like a 400whp setup you got there.
Congrats!!!!!!!!!!
Thanx guys, I really think the misfire is gone, after more driving today i should be able to know if its good or not, if it is, then more boost. I wanna get to 500 without going too much over. Krazy6, the auto is basically stock with a huge 40000 GVW cooler, drop resistor, and transgo shiftkit.
(Post 7698395)
Think that is all that Jime has as well. When I build up my project 4th gen it will have an auto. :D |
decent numbers atleast, in for dyno with no misses......
Nice work streetz. In for numbers when you decide to go to 15 psi.
Nice man :thumbsup: , suscribed until the next dyno.
Thanx guys, hopefully ill go to the next dyno soon. I have some motivation for now. I havent driven the car with the new alternator enough to know if the missing is gone or not, if its still there, then its going to be a while to figure it out since iv checked everything. if its gone then up the boost and hopefully dyno
I DEMAND VIDEOS!! nice numbers man, what are you tuning with?
Originally Posted by timmay5835
(Post 7699410)
I am tuning with EU and J&S |
so was it just the alty going bad or it being old ? you could have a draw somewhere if the new alty is doing the same ( or if I miss reading somewhere the issue is fixed)
anyways decent #s but im sure more power is untapped until the next dyno ! |
Originally Posted by NiZMo1o1
(Post 7699518)
what size is your intercooler & charge piping? Im curious to know what they might "max out" @
Originally Posted by accordingtou
(Post 7699676)
where is your boost level referenced from?
© 2024 MH Sub I, LLC dba Internet Brands
