Sponsored by:
Sponsored by:
V2 370CC Injector z32 MAF problem
Old 09-27-2010, 11:42 AM
Whats up org? I have a problem with my set up here
v2
2.87
6:1 fmu
Walbro 255
Stllen Charge Pipe
Stillen BOV
370 cc injectors
z32 MAF
Sard FPR
At about 75% throttle it misses really badly in 1st 2nd and 3rd in 4th and 5th its fine. also it misses when I come on the throttle after up shift.
I'm new to the and I dont have a clue so your help would be much
appreciated.
Thanks.
Solicitous is offline
Old 09-27-2010, 12:36 PM
Blown
v2
2.87
6:1 fmu
Walbro 255
Stllen Charge Pipe
Stillen BOV
370 cc injectors
z32 MAF
Sard FPR
appreciated.
Thanks.
Is your car tuned? Lack of tune or your ignition is breaking up.
cardana24 is offline
Old 09-27-2010, 04:15 PM
Turbo 3.5
whats your a/f and what spark plug gap are you running
t6378tp is offline
Old 09-28-2010, 08:43 AM
speedymax99's Avatar
Did you changed to 2 step colder plugs and run a smaller gap?
speedymax99 is offline
Old 09-28-2010, 02:11 PM
No
Don't know and .038
Yes and made it worse
Old 09-28-2010, 02:18 PM
Blown
either get on the dyno, or get a wideband O2 set up. You are just shooting in the dark until you know your a/f
My car ran similar to what you are describing before I tuned it.
Old 09-28-2010, 02:25 PM
Super Moderator
OP,
No need for 2 step colder plugs. Get some 1 step colder copper plugs, and gap them at .034
The Wizard is offline
Old 09-28-2010, 02:54 PM
Turbo 3.5
+1 with the statement above
If this does not work I would switch to a 4/1 disk cause it sounds like your running super rich. BTW, please get a WB02
t6378tp is offline
Old 09-28-2010, 02:58 PM
So lets get this straight go from step 2 to step 1 since i have them already what about just regaping them to .034??
Old 09-28-2010, 03:00 PM
well that could be. it ran fine with the stock injectors till about 5k with stock injectors thats why i swithched
Old 09-28-2010, 06:22 PM
Turbo 3.5
for trouble shooting purposes I would just clean and regap them but when the time comes I would get 1 step colder.
Also someone with a supercharger setup will know better but to me the car sounds like it's soo rich that it's bogging. With a wb02 or dyno you can confirm this but a walbro 255, 370cc and a 6-1 fmu in my mind equals too much fuel.
I would just run 370cc inj, walbro 255, afpr at a 1-1 raise rate and at the least a safc2 and ditch the fmu or switch to a 4-1 disk
t6378tp is offline
Old 09-28-2010, 06:24 PM
Turbo 3.5
the stock injectors were mostly likely maxed out at 5k depending on the fuel psi your running and hp your making.
t6378tp is offline
Old 09-30-2010, 11:50 PM
Thanks guys! The 4:1 did wonders!
Old 10-01-2010, 12:56 AM
Do you know base fuel pressure and a/f ratio through the whole rpm range?
But good job setting it up. Should be much faster than before!
Old 10-02-2010, 01:27 PM
You don't really need a fmu with those 370cc unless you are maxing them out.
akurtzer57 is offline
-ReLLiK-
04-29-2016 06:25 PM
BkGreen97
04-02-2016 05:47 AM
Maxboy23
51
09-15-2015 01:20 AM
ballerchris510
09-10-2015 09:35 PM
Quick Reply: V2 370CC Injector z32 MAF problem
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
