Another Almost Boosted 3.0
Old 05-25-2013, 06:28 PM
  #321
Turbo 3.5
t6378tp's Avatar
depending on what size injectors you have try bypassing the eu and see how the car runs
t6378tp is offline
Old 07-08-2013, 08:48 AM
  #322
Crusher103's Avatar
i have 440s, i did bypassing emanage car ran even worse lol. I ordered a knock sensor and it got here last week but i havent had a chance to work on my car with whats been going on, but i'll change the knock sensor and see where things go from there.
Crusher103 is offline
Old 07-08-2013, 05:13 PM
  #323
Turbo 3.5
t6378tp's Avatar
doubt if the ks will change anything
t6378tp is offline
Old 07-08-2013, 05:33 PM
  #324
emdot's Avatar
I had a similar issue with my maxima after my 02 sensor wire melted onto the exhaust. It was a grounding issue with the wire harness. I would test for continuity between all the logic grounds and back to ecu, and also signal wires back to the ecu from the sensors.
emdot is offline
Old 07-11-2013, 06:19 AM
  #325
Crusher103's Avatar
ok explain this one to me a little better. I did just buy a grounding kit so i want to re-do a lot of my grounds. But i have tested the sensors signal wires and they are checking out fine.
im tempted to drive it to dealership up the street just to see what they will say.
Old 07-11-2013, 09:37 AM
  #326
emdot's Avatar
If continuity from the sensor to the ecu are fine, look into the ground wire of the sensor. If you see any fluctuation of continuity, it may be a slightly weak ground. I'd check all your grounding points for clean contact points also if you haven't done so already.
My issue was the 5v signal was grounding from melted wires. I threw every code and changed all the sensors thinking I messed up the 3.5 swap somehow until I looked under the car.
Hope this helps and good luck. If you do go to the stealership, bring your own vaseline lol
emdot is offline
Old 07-11-2013, 02:48 PM
  #327
Crusher103's Avatar
Ayy i have been the one on the org threatening peoples bootyholes dont do that to me.
But i see what you are talking about, i'll give those a check.
Old 07-11-2013, 04:27 PM
  #328
emdot's Avatar
Hahaha I think we all know that dealership feels. I pepper my angus before I head in for service work lol
emdot is offline
Old 09-11-2013, 06:25 AM
  #329
Crusher103's Avatar
Well yesterday i might have found out what was making things erratic and why the car would not stabilize.
I went and bought a timing light because i have changed coilpacks, sensors, plugs nothing has improved the condition of the car and it progressively gets worse. I put the timing light on the car set it at 20* timing advance and it was spot on.....until the motor was revved. It was not a large amount but it was noticeable that the timing mark was bouncing back and forth and it was worse when the motor was increasing or decreasing in RPM.
Stretched Timing Chain. This would explain a lot, why im getting random misfires when the car is revved, why no matter what sensors i put on the car it keeps throwing the same codes. Its getting an erratic signal from the sensors so it assumes they are bad, of course its causing some knock in random cylinders so it tripped the knock senor code.
So here is the dilemma i am left with. I really do not feel like replacing a timing chain with the motor in the car, please spare me. So im just going to pay somebody to do it. Its between that and buying a 3.5 pray that the 5spd holds up and parting ways with the 3.0. I know plenty of mechanics from work who will give me a good price on labor. I will just get them to take the chain off I WILL SET THE TIMING, lord knows i dont want those guys setting my timing, then have clean up and put everything back on.
Old 09-11-2013, 08:20 AM
  #330
Buy gas.
Cover car in gas.
Light a match.
Walk away.
ChrisMan287 is offline
Old 09-11-2013, 01:00 PM
  #331
Ad·min·is·tra·tor
DanNY's Avatar
Buy gas.
Cover car in gas.
Light a match.
Walk away.
DanNY is offline
Old 10-18-2013, 12:08 PM
  #332
Crusher103's Avatar
Updates because they are fun. The timing chain has been changed, So i now have brand new primaries and secondaries, tensioner and water pump, and now new plans for the turbo.
The T04E is rebuildable despite being a ballbearing turbo BUT it looks like the fins have been touching the compressor housing so sending it too Turbonetics and having them find that out and then what they would charge to replace the compressor wheel and housing.....by the time im done getting raped by repair cost, i can buy a brand new turbo of any brand i want. So i took the cheap way out......
HX40/35 hybrid. This set up should be good for over 400whp with out much fuss. Of course DSM guys see 600whp out of these turbos.....dont see any 6cyl making that kind of power from them. But to be on the safe side as far as my power goals are concerned i went bigger than the "super40" the have a 62mm compressor wheel available for the HX40 so i got that plus the compressor housing to fit around it. The best part is my Turbine housing might not have to be touched to work on the holset, so i do not have to change the flanges.
Pics of all the new stuff will be posted as it arrives.
Old 10-18-2013, 02:37 PM
  #333
aackshun's Avatar
Take note.
I'm actually starting work on the red car's motor this evening.
We shall see who's car runs first.
That is all.
aackshun is offline
Old 10-18-2013, 04:46 PM
  #334
TurboA32's Avatar
Originally Posted by aackshun
Take note.
That is all.
That car has been down for a while hope to see it up and running soon
TurboA32 is offline
Old 10-20-2013, 09:23 AM
  #335
Crusher103's Avatar
Take note.
That is all.
Oh you best start movin b1tch look what came in the mail yesterday:
Sadly mine has been down longer
Old 10-20-2013, 09:26 AM
  #336
Crusher103's Avatar
My camera also discovered some damage i couldnt see:
Compressor wheel was chipped, so yea its just time to move on from the turbonetics unit. there seems to be no damage to the wheels on the holset but its just the turbine im concerned about its getting a new compressor wheel anyway.
Old 10-26-2013, 06:10 PM
  #337
Turbo 3.5
t6378tp's Avatar
so the car is running go now
t6378tp is offline
Old 10-26-2013, 06:43 PM
  #338
Crusher103's Avatar
Im going to find out soon as the rest of my b00st parts get here. But i have gone through every ignition and fuel control piece on that car and surprisingly a lot of the wiring on that car is in excellent shape(for a car built in April of 95). Timing chain(skipped tooth/stretched chain) was the had to be it. Power loss, off throttle backfires, misses during accel, and eventually the noise emited from the timing covers.
So i have the turbo here waiting for its rebuild kit and hopefully i wont need to take the turbine housing to the machine shop but if so whatever. i can go and start the car but cant drive it anywhere with out the something routing the exhuast somewhere other than directly onto the hood.
Although that top mounted turbo looks cool and blah blah blah sometimes i wish just for the sake of space it was flipped because there is more space in between the transmission and radiator and intake routing would be a lot easier.
Old 11-09-2013, 07:58 AM
  #339
Crusher103's Avatar
All the pieces are now here.
Old 11-09-2013, 09:08 AM
  #340
Maximeltman's Avatar
Cool! I bet it'll be a BEAST!!! Good job/luck
Maximeltman is offline
Old 12-14-2013, 08:37 PM
  #341
TravisCadello's Avatar
Any Update!
TravisCadello is offline
Old 12-15-2013, 06:29 AM
  #342
Crusher103's Avatar
None as of yet, ive been too busy to do anything these past couple weeks, i might get teh car back up with in the next week or 2 though.
Old 03-03-2014, 04:54 AM
  #343
Crusher103's Avatar
Spun bearing and/or rod knock. There is no winning.
Old 03-03-2014, 07:37 AM
  #344
Video is private. Give up all hope.
Old 03-03-2014, 08:15 AM
  #345
Crusher103's Avatar
vid should be good. Pictars from last night though:
Got the new wheels on, new suspension is on it just needs to be adjusted.
Old 03-03-2014, 03:41 PM
  #346
Turbo 3.5
t6378tp's Avatar
U and this car
t6378tp is offline
Old 03-03-2014, 03:49 PM
  #347
Crusher103's Avatar
This car is just made from something different, even when things are done right it finds something to do wrong and its inexplicable why things go wrong on it. I dont want to give up on it just because it has soo much time in it. And the list of new parts goes like this:
New turbo HX40/35
New BC coils
New wheels
New sound system
New timing chains and tensioners
So here is the decision i have to make. Fix this 3.0, move to a 3.5, or scrap the project.
Old 03-03-2014, 07:49 PM
  #348
chrome91's Avatar
you sure thats not from the top end? sounds kinda like a fecked lifter to me. my 3rd gen spun a bearing when the motor went and it was a deeper noise than that
chrome91 is offline
Old 03-03-2014, 10:08 PM
  #349
Quickywd01's Avatar
Don't give up, you're almost there. It's testing you to see how bad you want it.
Quickywd01 is offline
Old 03-04-2014, 12:47 PM
  #350
Turbo 3.5
t6378tp's Avatar
I would just drop a stock 3.0 in there with a mevi or 00vi and be done with it
t6378tp is offline
Old 03-04-2014, 02:15 PM
  #351
Quickywd01's Avatar
I agree, 3.0's are strong for boost.
Old 03-04-2014, 02:19 PM
  #352
Fakie J Farkerton's Avatar
Fakie J Farkerton is offline
Old 03-04-2014, 02:26 PM
  #353
Quickywd01's Avatar
Originally Posted by Fakie J Farkerton
Not very nice, play nice.
Old 03-04-2014, 02:57 PM
  #354
I am.
Just using his smiley.
He will get this..eventually.
Old 03-04-2014, 03:56 PM
  #355
Max streets's Avatar
I think since u already did the timing u should rebuild it.another thing I learned my lesson,if u already doing the timing on a vq u should just rebuild it becuaus it's a lot work to get to the timing u might as well make it brand new,since u know u already boosting it,more wear and tea than usual.
Max streets is offline
Old 03-04-2014, 05:54 PM
  #356
Quickywd01's Avatar
I am.
I thought so haha sorry.
Old 03-22-2014, 11:26 AM
  #357
Crusher103's Avatar
Motor went Kaput yesterday evening when i was trying to move the car. Sounded like several valves dropped and now the motor will not restart so the 3.0 is done....but what is coming next might be equally interesting....I'll be the first on here to do it i know that.
Old 03-23-2014, 02:09 PM
  #358
schmellyfart's Avatar
In for progress on this next motor.
schmellyfart is offline
Old 03-24-2014, 10:54 PM
  #359
Quickywd01's Avatar
VQ hybrid?
Old 03-25-2014, 05:44 AM
  #360
Whatever it is, just make sure it doesn't blow up.
Quick Reply: Another Almost Boosted 3.0
