S/C Max help in Ohio
Anyone in Ohio that knows much about supercharged maxima's? Or does anyone know any shops that I can get it checked out? I'm a gear head but it's my first Nissan, let alone one that is S/C'd. :D
Main things I am concerned with, while idleling the oil pressure will bounce around sometimes dropping below 10psi. However it does idle at around 600 rpm, so maybe it's not an issue. It also seems to bounce at idle (rev between 500-700), normal or no? If I turn the A/C on and put engine under load, it stops. I had belts slipping above 5k, tightened and runs much better now and seems like less soot is pouring out the exhaust. Thanks for any help! Here are the specs on my car: 2000 Maxima SE, 161K miles, 5 speed Vortech V2 T-Trim Supercharger Front mounted intercooler 2.87" Pulley RC550cc Injectors Walbro 255 Fuel Pump Aeromotive fuel pressure regulator Greddy E Manage (Blue) Vortech Maxflow Race Bypass Valve Cold Air Intake Piping O2 Simulator Cattman headers Stainless Steel Test pipe 3” Cattman catback B&M Short Shifter ACT 6 puck sprung disc w/Competition heavy duty pressure plate SS Clutch line PAR third & Forth Gear (PAR Synchromesh Racing Gear). Eibach Pro-Kit Spring System on adjustable Tokico Illumina struts Cattman Front Strut Tower Bar Cattman Rear Sway Bar Defi Oil pressure gauge Defi Fuel pressure gauge Defi Boost gauge Defi Link Control Unit II |
Sounds normal for a modified nissan to me. You can try to clean your IAC valve to see if that cleans up the idle.
Good to hear, thanks.
Yep that was my old Maxima, clean the MAF, I used to spray clean the MAF once a month.
© 2024 MH Sub I, LLC dba Internet Brands
