Need help on my gt28rs turbo
Old 10-12-2012, 10:23 PM
juggalo_g's Avatar
I have noticed people have used oil for most feeds and returns
I'm using the ve30de motor
I have my return to the pan and wondering where I can my feed from?
juggalo_g is offline
Old 10-13-2012, 10:51 AM
Turbo 3.5
t6378tp's Avatar
get a block tee fitting for the oil psi switch or a oil sandwich plate
t6378tp is offline
Old 10-14-2012, 08:48 AM
Crusher103's Avatar
GT28 on a 3L.....are you trying to run twins?
Crusher103 is offline
Old 10-14-2012, 11:24 PM
juggalo_g's Avatar
Single turbo my return is to the Pan
Old 10-15-2012, 11:18 AM
Turbo 4th Gen
93altima's Avatar
thats a little turbo for a 3.0
93altima is offline
Old 10-15-2012, 03:27 PM
ShocknAwe's Avatar
how did someone sell you on the 28?
ShocknAwe is offline
Old 10-15-2012, 03:49 PM
kasso28's Avatar
I've never heard of anyone NOT using oil in a turbo. No offense, but are you ready for turbo?
kasso28 is offline
Old 10-15-2012, 04:26 PM
KH3 by popular demand
maxgtr2000's Avatar
Less is more in 2012...
maxgtr2000 is offline
Old 10-15-2012, 05:29 PM
unkn0wn180's Avatar
This is the easiest way. +1
Otherwise you will need to drill into the block somewhere and have a fitting done up.
Oil return location is not terribly important, as long as it can be correctly gravity fed and not get blocked up. Best to ensure ur fittings are large enough for this.
Akaik the VQ30det and vq30det have a large frame t28 turbo. A larger style t28 will do fine for a 3l running low boost. It will defiantly want to lose toward the top end, but should provide some quick low down boost.
A small frame 28 turbo would be interesting, but i guess it all depends on what spec 28 turbo you are using.
a large frame gtx28 with .86 housing would go hard on a 3l,
without knowing details of his turbo it all speculation. It will be better than NA for sure, but won't break any dynos.
unkn0wn180 is offline
Old 10-15-2012, 08:51 PM
kasso28's Avatar
turbo is not always better than N/A. Think about the cost for the whole setup, he'd probably make more power spending that same amount on an N/A setup than with that turbo.
If you're gonna spend that kind of money, Go big or Go home!
kasso28 is offline
Old 10-16-2012, 06:01 AM
Turbo 3.5
t6378tp's Avatar
http://www.compturbo.com/spotlights/oilless
t6378tp is offline
Old 10-16-2012, 07:46 PM
kasso28's Avatar
lmao I stand corrected, but whats the cost of one of those?
kasso28 is offline
Old 10-16-2012, 08:49 PM
cw96's Avatar
We are a distributor for Comp. Just give us a call and talk to Scott.We are making a rear mount bolt on turbo kit using these oilless turbos for the 95-99 maxs for now. We are bustin *** getting Joe's (the owner of comp turbo) supra ready for SEMA in Las Vegas and we only have a few weeks left so it will be next month before the kit finished.
http://yellowmunsontuning.com/
cw96 is offline
Old 10-16-2012, 11:32 PM
juggalo_g's Avatar
Jim wolf sold it to me a few years back my car has been sitting for a while due to health conditions my piping is done
Here is the specs
http://intensepower.com/noname28.html
And should the be 90 deg fittings at the turbo for oil feeds
Old 10-17-2012, 03:55 PM
maxgtr2000's Avatar
In a rear mount you get rid of the oil lines for that turbo but you have to run water lines instead, not much of an advantage over running oil lines imo. Please advise.
Old 10-21-2012, 04:52 PM
kasso28's Avatar
Actually it is an advantage cause you can have an independent cooling loop setup in your trunk, similar to the way you water cool a water to air intercooler. I gotta look into this setup, sounds interesting...
kasso28 is offline
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
BkGreen97
04-02-2016 05:47 AM
09maxshawn11
09-30-2015 10:28 AM
Keyno McMike
09-21-2015 07:18 AM
Quick Reply: Need help on my gt28rs turbo
