Nistune tech ?
I just finished installing a new engine and was working on the initial start up. I updated nistune just yesterday. (nistune was previously installed and operating fine)
I had a fuel line leak and my cam sensor connector was loose and all this time I was getting normal fuel prime. Fired the car with an old map and it started right up but died before I could get the K constant adjusted. I had to leave for an appointment. When I came back and started at it again I had no fuel prime. I checked the pump, and it operates. I dont have voltage at the tank. I pulled the fuel relay and its good to go. I checked the power and ground coming to the relay and I am not getting an ecu signal to the relay.... Any ideas? |
When you turn the key on does the check engine light up or see lights turn on on side of ecu?
© 2024 MH Sub I, LLC dba Internet Brands
