question, 45 series tires for 18x8's ??
Hello all, I have the Enkei RPM2 wheels in 18x8 size, I am currently running 40 series tires, the ride is a bit rough for my tastes, can I put a 45 series tire on these? Any suggestions for an all season tire in this size? I need a more comfortable ride but I would like to keep the 18's any suggestions on what to do? Thanks in advance
http://www.tirerack.com/tires/tires....omCompare1=yes
The tires are highly rated for its grip in dry and wet. However, I've heard that the sidewall is quite soft, so it wouldnt handle as well. ~limsandy |
Sounds good, but will they fit? It seems that those aren't recommended for 18x8's
They'll fit fine. Don't worry.
~limsandy |
How soon are you putting on the new tires so I can hear your thoughts on the ride difference, handling, etc.? Good luck with it... |
Yeah 235 would be fine too, I am not sure about the 225 since these are 18x8's, I will probably get what ever is rated high and is all weather. Thanks for the info.
those sizes should fit... i have 255/45R18 tires on mine right now which is bigger and any of those your looking at.
| All times are GMT -7. The time now is 06:26 PM. |
