Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Tires and Wheels (https://maxima.org/forums/tires-wheels-53/)
-   -   6th gen SE wheels and 350Z wheels? What's the difference? (https://maxima.org/forums/tires-wheels/294225-6th-gen-se-wheels-350z-wheels-whats-difference.html)
2k3TitaniumSe Apr 2, 2005 02:09 PM
Is there a difference? My guess is that they're the same style but the Z has wider wheels?
Triple8Sol Apr 5, 2005 04:26 PM
If u look at the spokes, they're different. Also, the Z wheels are 18x8 30mm offset. The 6th gen Max wheels are 18x7.5...not sure of offset, but I'd guess more like 40...
CCS2k1Max Apr 5, 2005 06:38 PM
Also, aren't the Z's staggered??? I thought the fronts were 18x7.5", 33 mm offset and the rears 18x8", 30 mm offset (I may have the offsets reversed).
CanadianMoFo Apr 5, 2005 07:49 PM
Z's are staggered for sure. Also as CCS2k1Max points out the offset is different. Stock offset on a 6th gen is 40mm. Going down to a 30 is quite a change.
Ammi Apr 5, 2005 08:25 PM
they are all same size but come w/ different size tires
CCS2k1Max Apr 5, 2005 08:53 PM
We're all correct. Depending on the model/option, the Z's 18"s can be staggered, wheel and/or tire size. The coupe can have 18x8.5" 33 mm rears. This is from the 04 Z owners manual (I left out the 17s):
Size Offset
in (mm)
Coupe Aluminum
Front
18 x 8JJ* 1.18 (30)
Rear
18 x 8JJ* 1.18 (30)
18 x 8-1/2JJ* 1.30 (33)
Roadster Aluminum
Front
18 x 8JJ* 1.18 (30)
Rear
18 x 8JJ* 1.18 (30)
Triple8Sol Apr 6, 2005 05:45 PM
The 18x8.5 is probably referring to the Track model rims by Ray's. The Touring/Performance models came with 18x8 all around. Just 225 tires in front and 245 tires in rear. I have a set as well. Don't believe me? Check 350Zmotoring.com
