Good PSI for 17's
What would be the ideal pressure for a set of 17's on my 98? Tires are Fuzion ZRi and the size is 225-45-17. I am under the max psi marked on the tire, but up over the manufacturer recommended psi. I would not think the manufacturer recommended would apply to aftermarket plus size wheels.
Thanks. |
33 psiiiiiiiiiiiiiiii
Don't worry about the manufacturer psi.. go by what it says on the tire.
Also, if it's a little lower than max, the ride will be smoother.. if it's at max (don't go over) you'll have better gas mileage. |
235/45R17 ZRis on 01 OEM SE wheels. I run 37-38 psi. It's a little harsh, but I want/like a fast steering response and stable cornering.
p.s Better get used to LOUD noise and tramming on every road imperfection. |
| All times are GMT -7. The time now is 08:00 PM. |
