Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Tires and Wheels (https://maxima.org/forums/tires-wheels-53/)
-   -   Will KYB's AGX shocks help? (https://maxima.org/forums/tires-wheels/361705-will-kybs-agx-shocks-help.html)
lilmyth Jul 18, 2006 08:12 AM
First, Thanks Boone for your advice..
Just want to get other opinions as well...
I have a 04 Max that I just added rims and tires.. However, I'm experiencing some rubbing. Everyone I ask is kinda surprised at this... I was assured these would fit with no issues.. No rubbing while normal driving, however, if I hit a bumb, then you can hear it... I have yet to carry passagers - I know it will only be worst. Any advice or thoughts would be appreciated...
This is all I have on it.. Do you think adding the shock would make a difference, or should I put the original springs back on the rear only, or will I need the shocks either way?
Tires
245/35/20
Eibach Springs
jlars205 Jul 18, 2006 01:49 PM
Did you add springs at the same time as the new rims? And how do the rolling diameters of your old and new tires compare?
Ammi Jul 18, 2006 06:36 PM
it's a good practice to install aftermarket struts while you are installing springs. Only way you won't rub is to go back to OEM springs or roll your fenders.
CanadianMoFo Jul 19, 2006 04:39 AM
Maybe just a small wheel spacer to bring the inside edge of the tire out beyond the springs. If that is where it is rubbing.
lilmyth Jul 19, 2006 07:11 AM
I had the Eibach springs on for about a year. I dunno about the rolling diameter comparison.. Not sure how to do this...
lilmyth Jul 19, 2006 07:15 AM
Yeah, I will probably put the original springs back on. Thanks for the advice. Do you think I need the aftermarket shocks in the rear as well?
Ammi Jul 19, 2006 05:09 PM
I always install aftermarket struts along w/ my springs; both front and back.
