Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Tires and Wheels (https://maxima.org/forums/tires-wheels-53/)
-   -   New question...225/60/16's..rub? (https://maxima.org/forums/tires-wheels/376334-new-question-225-60-16s-rub.html)
ke.max Nov 26, 2006 10:09 PM
Anyone on the board know if 225/60/16's will rub on a 5.5 gen?
I'm really not too sure...as I've seen 225/55/17's with no rubbing...
and now going up to a 60 but rim size down to a 16...
Any input would be appreciated!
96blkonblkse Nov 29, 2006 06:55 PM
You might rub. The stock tire size diameter is 25.9 while the 225/60/16 is 26.6. There is very little room with the stock wheel/tire setup on the 5.5 gen. So basically stay as close to stock diameter as you can.
I think if you have to go for 16's get 225/55/16. That is almost an identical diameter to the stock tire size which is what you want. The diameter of 225/55/16 is 25.7.
check out http://www.miata.net/garage/tirecalc.html
ke.max Nov 30, 2006 11:34 PM
Thanks for the reply.!
I actually just installed them today....no rubbing :D *woot woot* haha
Thanks for the input and the link though.
