GTI BBS's on a 5th gen
Situation: I just got offered a killer deal on a set of the VW BBS wheels with tires that come with the GTI. The obvious issue here is that they're 5x100 and I need 5x114.3 for my Maxima. Is there a set of adapters I can buy for them? I've been looking all over and I see tons of 5x100 to 5x114 spacer/adapters but I can't seem to find the opposite. Or is there a way to get them modified at a shop if I can't go the adapter route (which I would prefer to do) I'm getting a killer deal on these so if I have to invest a little bit of money to get this to work this out that's not a problem. Any answers or advice is greatly appreciated.
EDIT: after an EXTENSIVE amount of searching I think I finally found what I need: http://cgi.ebay.com/ebaymotors/Wheel...ht_2777wt_1165 Do these look ok? a little on the expensive side, but if it's what I have to do to make it work then I'm fine with spending the money on them. |
those seem like they would work. im curious to see pics
Those adaptors are definitely what you need and they will work. Any specs on the BBS'?
http://adaptitusa.com/
why go through so much trouble for merely such generic wheels? stay away from cheap ebay stuff, unless you want your wheels to roll past you on the freeway |
| All times are GMT -7. The time now is 09:22 PM. |
