4th Gen 19x9.5 Offset and Tire size
Looking at a set of rims and I want them to be as flush as possible. The 9.5 comes in two offsets, 35 an 40 which would be best for the front wheels? And what tire size should I be looking for with this size?
Thanks!
Thanks!
I think our stock wheels are 16x6.5 with 45 offset I think...so if you 2.5" wider with the CURRENT offset you'll be sitting pretty damn flush...
do you want poke at all? If not, I'd probably go with the 40 offset and (if needed) add 5mm spacer. BUt I don't kno, someone else should check my math and confirm.
Thanks Guys! Do you think I could fit a 245 or 255 without much issues? Or perhaps run a 40 offset in the front to help accommodate a wider tire? I love the look of stretched tires but this car is turboed and it would be nice to have some extra contact path if not it will be fine but if it's a option I would rather go that route.
This.
The car will be dropped as much as possible to accommodate whatever the widest tire size I can fit. So if it is not slammed that is ok with me.
been rolling 19x9.5 with a 35 offset slammed on sprints for years
http://www.cardomain.com/ride/199167/1999-nissan-maxima
Maxima_Joe
11-25-2015 08:19 AM
Cant_Get_Ryte
08-28-2015 06:41 AM
