View Poll Results: What type of tire should I go with?
Go with 235/40/18-good compromise on width/height
0%
Voters: 6. You may not vote on this poll
Tire size/fitment gurus step in
Well, its time for a new set of tires and I want experienced opinions. I pieced together my current setup. 350Z touring V1 rims (18x8@33offset) and 225/45/18 kuhmo's last year. Since I am finally getting new tires, I want to buy the best fitting set of tires I can. I am lowered about 1.75" inches in the front and 1.5 in the back. I am going to get 10mm spacers for the rear to match how the front rims fit aggressively.
here is the front tire in the well...
Here is the look down the side...
Thanks for the input guys!
- Should I go with 225/45/18 again?
- Should I go with a wider 235/45/18?
- Should I go with with a lower profile but still wide 245/40/18?
- Should I go with 235/40/18 for a good compromise between width and height?
Ok to get a definite size, I am going ahead with getting the fitment right. Tomorrow the rear quarters are getting rolled. Friday I am getting 20mm spacers. How it fits and compresses under load will give me my answer. Now if I could just sit lower.....
Word. Best part about the south is you can get away with a summer compound because snowfall is less than 10" a year. I'm still debating 225/45 again or a 235/40. Tires are super close to the freshly rolled edges.
Yea I have 18x8 10offset (30+20mm spacer) . It seems to be running into either the bumper inner edge or upper inner rear fender with my wife and two kids in the car on a hard road dip. H&R springs (front 1/2 coil cut). It blows my mind how much narrower the track is in the rear.
Whenever I'm grocery haulin' the rub gets worse. Not sure why it's that way either. The same way on 4th gens. And on Chevy trucks it's the same way. My Pathfinder is opposite, rears are fine, fronts are a little sunk in. Where's the balance Nissan!
Which year pathy do you have. My Wifey rocks a 2006 pathfinder SE. Kinda want a stiffer suspension, it's too floaty when loaded with people.
Well I know with our trailing arm rear beam with torsion rod it tracks up and to the right when compressing.
Oh yeah when lowered the torsion bar binds up and sends the tires to one side. Didn't mean I wasn't sure about that issue I was saying I wasn't sure about why the track is different front and rear on the Maximas.
R51 suspension is too floaty stock. I went with front coilovers and rear shocks and springs. PRG/RadFlo. Expensive but worth it. Ride is fantastic now. Not floaty.
