Tire skin peeling
Old 08-25-2017, 10:23 AM
hithesh's Avatar
Tire skin peeling
My two front tires seem to have some peeling near the edges. What can cause this?
Attached Thumbnails Tire skin peeling-img_20170723_191045.jpg   Tire skin peeling-img_20170723_191032.jpg
hithesh is offline
Old 08-25-2017, 11:25 AM
Turbobink's Avatar
Alignment ...
Improper inflation ...
Both ...
Turbobink is offline
Old 08-26-2017, 05:03 PM
hithesh's Avatar
Thanks.
Are the tires screwed.
Should I get them re-aligned or just get a new pair.
hithesh is offline
Old 08-26-2017, 05:42 PM
Turbobink's Avatar
I can't see the entire tread but if the wear in your photos is the worst of it, I'd say get yourself an alignment, maintain your tire pressure and you should be good for quite a while.
Old 09-07-2017, 05:08 PM
TableRocker's Avatar
These tires are pretty much done. The one on the right especially...you'd have ZERO grip in any sort of standing water. Unless the budget just doesn't allow it at this time, I'd definitely get new tires and have the alignment done.
TableRocker is offline
