1984 maxima
Old 05-05-2015, 05:45 AM
trini16's Avatar
1984 maxima
Hi everyone I'm new to this Forum.. I just picked up 1984 Maxima need some info on size of rims i can put on my car the offset to use also would like to lower a bit. thanks Anderson
trini16 is offline
Old 05-05-2015, 04:48 PM
aw11power's Avatar
I dont know much about wheels for 1st gens, but check out cardana24s thread below, he gives some insight on springs.
aw11power is offline
Old 05-25-2015, 11:38 AM
montirdokar's Avatar
I have a 83 wagon and had a84 sedan, you can use 15" 300zx (1984/1985) on either, with 205/55 or 225/50 or 205/60 (rubs the fender pretty bad without lowering) or 280zx turbo (offset 10) on the wagon only (I've seen someone put it on the sedan but you have to R/R it with the jack on the swing arm in the back ) or 14 inch rims with minimum offset 15 mm (anything less would rub the fender very bad without lowering )using 215/60 or 225/60 , cornering improved like crazy without lowering, 15 in tires are way cheaper now, rides better on 15 in IMHO
montirdokar is offline
Goffery2uned
08-21-2015 09:50 PM
julian888
08-06-2015 04:39 AM
julian888
08-05-2015 08:26 PM
Quick Reply: 1984 maxima
