Strange Electrical Issues
#41
The box just says CLUTCH. I do have an INHIBIT CLUTCH INTERLOCK whatever that is but the one that just says clutch has no wires coming through or a housing for a relay. It is just blank.
#42
#43
#48
Alright so I came home and gave it a try. My Inhibit fuse looks different from yours. However, I went for it anyways. I had my buddy move the wire from spot to spot and all of a sudden it started cranking all by it's self when he put in in a certain hole. I had the car on the on position. For some reason I couldn't get it to start or not crank by it's self. I'll get on my pc and post a picture of what mine looks like.
#49
#50
Find terminals 6 and 7, and jump them together. The relay will be marked if the socket isn't. Turning the key to "start" is necessary, as it energizes another circuit that enriches the A/F mix for starting.
#51
Plug the relay back in and look underneath it to the wires that run into it. Tap into the green wire with an orange stripe with one end of a wire and ground the other end of that wire. Try starting. Careful it will start in any gear with or without the clutch depressed.
#52
Try these two.
Honeslty, If this were my car, I would take the G/OR wire at E14 and splice into the G/OR clutch pedal wire under the dash. Of course this is just looking at PDF manuals, I don't know what your car actually has at this point.
He just replaced a hacked harness, rehacking at this point would be stupid. Besides your method might disable cruise control.
#53
#54
It most definitely would. Also, having the relay out of the socket will disable the cruise control. To allow the cruise to work, you would need to add a 2nd jumper in pins 3 & 4.
asand1 - please forgive me for using your photo.
#55
Try these two.
Cruise works fine in my car. Just have to disengage with the brake pedal
#56
You're talking about splicing but my suggestion to tap into a wire is stupid? I don't understand that one. We are suggesting the same thing. I suggested the clutch pedal circuit in a previous post. Going straight to ground is meant to temporarily prove that it will turn over and start.
H3ll, why not just ground the wire at E14 for testing, and then splice it into the clutch switch wire? and yes I am saying the same thing as you, I am just trying to do it with as little cutting as possible.
#57
^^^Semantics I guess. I "tapped" into the relay wire by simply wedging one end of the wire from the bottom in beside the G/OR wire and then grounding. No cutting required. Not until I knew it worked.
Good luck OP. Hope the suggestions worked out for you.
#58
#60
Glad to hear. Your old harness should have the orange/green wire that ran to your clutch pedal. Use this wire to splice to the orange/green wire you have grounded, and everything should work like stock.
Be careful, the multimeter will only carry 10 amp before blowing the internal fuse.
pktaske
05-06-2016 07:49 AM
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
pktaske
09-04-2015 08:40 AM
