Alternator 12mm post nut
Greetings gents, just got the remaining portion of my grounding kit, and i'm having trouble removing the 12mm alternator post nut. There is a metal clamp underneath the nut that's turning at the same time making the wiring twist as I turn trying to get it off.
I know I can't be the only person that has had this problem. I've search the forum and everyone says just remove the nut. Thanks in advance for any positive feed back.
clamp does not matter remove nut place gauge wire then put the nut back it is that simplei just did the Big 4 upgrade on my 02 max and it was very quick.........long extension with a 12 socket and it comes out easy peasy
Appreciate the quick feedback fellas, after I posted, went back and held the metal piece with my hand as I turned the nut, and it came off easy peasy, and all is well again...time to check for all these promised differences
George, something just doesn't seem right about using flammable liquids where sparks could possibly fly
lowpost99
05-16-2021 11:18 AM
06-06-2017 02:01 PM
