Engine power under 4k RPM seems low, need maintenance?
Beyond the 4k rpm the engine is a beast, but if i shift from 2nd at 4.3k rpm up to 3rd at 3.7k, i feel like ive lost half the power. Its inconsistent too, sometimes running it it seems fine, but other times it seems like power is lower (~half like mentioned before).
Me setup
5th gen, 3.5L VQ35DE
My setup is stock outside of a resonator being removed by the last owner, and the same guy put on a ram air intake.
My diagnostic guesses
I feel like something isnt coordinating right in the engine below 4k. or exhaust isnt as free as it could be?
Intake filter is not in great shape either, covered in part by rust dust.
Questions - Need help
Is this normal?
Is it a vacuum valve? second one opens at 4.5k or something?
Is it exhaust related? CAT blown? (high rpm could power through it?)
Sensors? MAF dirty?
What can i diagnose/clean to smooth out the power?
Me setup
Is this normal?
Sensors? MAF dirty?
Easier for us if you post original post in here instead of linking. That said it could be normal because of ram intake as you lose some midrange power with that setup. Power loss is subjective so tough to say. It could also be your MAF. Try cleaning it. Definitely clean your air filter. It may also be your power valve in the intake manifold. Do a search for "power valve" to diagnose and repair if needed.
Beyond the 4k rpm the engine is a beast, but if i shift from 2nd at 4.3k rpm up to 3rd at 3.7k, i feel like ive lost half the power. Its inconsistent too, sometimes running it it seems fine, but other times it seems like power is lower (~half like mentioned before). Me setup 5th gen, 3.5L VQ35DE My setup is stock outside of a resonator being removed by the last owner, and the same guy put on a ram air intake. My diagnostic guesses I feel like something isnt coordinating right in the engine below 4k. or exhaust isnt as free as it could be? Intake filter is not in great shape either, covered in part by rust dust. Questions - Need help Is this normal? Is it a vacuum valve? second one opens at 4.5k or something? Is it exhaust related? CAT blown? (high rpm could power through it?) Sensors? MAF dirty? What can i diagnose/clean to smooth out the power?
I suspect i am getting slip.....
in 4th, 5th(most easily), 6th im pressing hard on the gas and the revs go up rapidly (500 to 1k rpm) but the car doesnt change speed, then the revs drop as it seems to match up more??
why does it slip at first then return to grip? consistently
Finkle
09-27-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
