thermal intake spacers car wont stay on after install
Old 08-11-2015, 05:49 AM
Maxboy23's Avatar
Just installed the cxj performance intake spacers and the the car barely starts.i turn on the key car idles really rough and the rpms go up and down and it just dies....i think something is unplugged but i cant find what i dont think i have intake leak we tightened them good and put a light layer if silicone but didnt tighten down the upper intake manifold in the numerical order i dont knowbif that matters or or not..
Maxboy23 is offline
Old 08-11-2015, 05:58 AM
Derrick2k2SE's Avatar
Sounds like you may have left a vacuum line off. If you left a sensor unplugged it would throw a code.
If you get it running can you rev it and get past the roughness to keep it running at higher RPM?
This wouldn't be caused by not following the torque pattern as long as you followed some sort of pattern and didn't just torque each one all the way down one at a time.
Derrick2k2SE is offline
Old 08-11-2015, 06:00 AM
aackshun's Avatar
Vacuum leak.
Do it again.
aackshun is offline
Old 08-11-2015, 06:13 AM
Maxboy23's Avatar
I csn rev it but it only stays on for like 5 sec like its hesitant
Maxboy23 is offline
Old 08-11-2015, 06:49 AM
Make sure you didn't split the intake boot. Check every fold in it for cracks. If it's sucking in air that the MAF doesn't know about it will cause problems.
Old 08-11-2015, 06:57 AM
Maxboy23's Avatar
I have a aftermarket intake adapter its not the crappy stock one
Maxboy23 is offline
Old 08-11-2015, 08:31 AM
DennisMik's Avatar
This sounds like when the IACV goes bad on a 5.0. Are you sure you have it plugged in?
Since you didn't say what year car you have, this may not apply to your car.
DennisMik is offline
Old 08-11-2015, 11:59 AM
Maxboy23's Avatar
Its a 2002 maxima
Maxboy23 is offline
Lakersallday24
06-16-2019 01:35 AM
Ben2003GLE
31
07-17-2016 08:13 AM
MAXSE5SPD
08-23-2015 12:06 PM
cheftoo
08-20-2015 05:17 AM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: thermal intake spacers car wont stay on after install
