Sponsored by:
Sponsored by:
General consensus on when to change tranny fluid?
Old 10-30-2015, 03:01 PM
Maximam's Avatar
I'm at 61k miles and wanted to get a consensus on when other feel dropping 5 quarts out of the CVT and refilling is needed?
Opinions?
Maximam is offline
Old 10-30-2015, 03:05 PM
1996blackmax's Avatar
I do this every 30k miles.
1996blackmax is offline
Old 10-30-2015, 04:11 PM
zoemayne's Avatar
I did mine at 50k... I would recommend doing it at 40k. You will notice the difference. I'm not a heavy driver.
zoemayne is offline
Old 10-30-2015, 04:58 PM
MaximaDrvr's Avatar
I do it every 30k.
At 141k now.
MaximaDrvr is offline
Old 10-30-2015, 05:56 PM
Maxgig's Avatar
I change my cvt every 50k and my oil every 5k.
Maxgig is offline
Old 10-30-2015, 06:39 PM
Maximam's Avatar
Change it it is then. Anyone have the best place to buy the fluid? Links?
Maximam is offline
Old 10-30-2015, 07:23 PM
Richard66's Avatar
Get the NS2 CVT oil from the dealership. It might cost a few extra bucks but it will be the real thing, OEM, unlike what you might get off of EBAY. Why take a chance of ruining your car by putting in the wrong thing.
Richard66 is offline
Old 10-31-2015, 06:39 PM
Maxgig's Avatar
I've bought mine from the dealer and from ebay. The time I bought from ebay the seller was a Nissan parts distributor so I felt confident buying from them. I've personally had no issues and would have bought again from ebay but I was moving from Cali back to Kansas and wanted the fluid right away.
Maxgig is offline
Old 11-01-2015, 05:47 AM
LtLeary's Avatar
Don't forget to change the filter. I am at 310,000 and drain and fill every 60k.
LtLeary is offline
Old 11-02-2015, 12:38 PM
LSExplorer22's Avatar
I'm at 101,300 miles and I plan on doing it for the first time at 105,000 miles. I have had no issues with my transmission ever.
LSExplorer22 is offline
Old 11-02-2015, 01:18 PM
Maximam's Avatar
Done. Straight forward deal. Bought the cheap $2 7qt pan from Walmart that has quarts labeled to measure the drain. Purchased 5 qts from Nissan at $17/ea. that was after a haggle from $19.95. 4.5 quarts came out of mine when on ramps. Be careful when you remove the drain bolt, the fluid comes out very fast, it's like water. The filter will have to wait until I order it since it was not in stock. The parts counter guy at Nissan said it has no filter. I gave him a part number and asked him what that was then. ;-)
Maximam is offline
Old 11-03-2015, 01:05 PM
I love lamp.
maximase86's Avatar
I did mine at 30ish k.
S
maximase86 is offline
Old 11-03-2015, 01:12 PM
Maxxi12's Avatar
I think most people are leaning in the direction that you should go ahead and do it...
I've got almost 30k on mine and haven't done it yet. Probably will do it soon. No issues with it.
Maxxi12 is offline
Old 11-09-2015, 11:37 AM
VVhite-0ut's Avatar
What's the Part# for the CVT oil filter? I'm sure most Nissan techs will argue there isn't one so I'd like to have my information correct when I approach that occasion. TIA!
VVhite-0ut is offline
Old 11-10-2015, 06:56 AM
fame126's Avatar
I agree! Better to be prepared. I'd like to know as well as I'm coming up on 60k to have mine done
fame126 is offline
Old 11-10-2015, 09:04 AM
LtLeary's Avatar
317261XE0A around $12
LtLeary is offline
Old 11-11-2015, 11:36 PM
carlem9's Avatar
Every 30k is a good interval but you can go beyond it a little.
carlem9 is offline
Old 11-24-2015, 04:09 PM
Zygi's Avatar
CVT fluid change
I would change it, if It were my car. My personal experience:
I did mine at 34000 (It's a 2011 max) and the fluid that came out wasn't very clean-looking at all but wasn't too dirty either. I might do the next change at around 60000 if not before that.
Zygi is offline
Old 11-24-2015, 04:21 PM
Zygi's Avatar
Filter? So you dropped the pan then, in addition to draining the fluid right?
I just did a drain and refill at 34000. Btw. awesome mileage; makes me feel more confident about my car. You're also lucky you don't have the infamous bearing knock.
Zygi is offline
Old 11-24-2015, 04:25 PM
Zygi's Avatar
317261XE0A corresponds to:
"CONTROL VALVE (ATM) - OIL FILTER ASSY-AUTO TRANSMISSION"
Zygi is offline
Old 11-26-2015, 06:41 AM
LtLeary's Avatar
Originally Posted by Zygi
Filter? So you dropped the pan then, in addition to draining the fluid right? I just did a drain and refill at 34000. Btw. awesome mileage; makes me feel more confident about my car. You're also lucky you don't have the infamous bearing knock.
No pan dropping required. The filter is on the return line from the transmission oil cooler. You will see it behind the splash shield on the front left wheel well. Looks like an older style fuel filter.
LtLeary is offline
Old 11-29-2015, 03:10 PM
MDSUPERSTAR's Avatar
https://www.parts.com/index.cfm?fuse...NAL-OIL-FILTER
MDSUPERSTAR is offline
Old 12-01-2015, 02:58 PM
Zygi's Avatar
Description says it's for a 2007 maxima
Zygi is offline
Old 12-01-2015, 06:22 PM
Maximam's Avatar
Same part.
Maximam is offline
Old 01-19-2016, 07:35 AM
michaelle8885's Avatar
sorry, what's the consensus on this CVT fluid filter? I haven't heard anything about it and can't find anything in the manual about CVT fluid filter. The Service Maintenance never mentions anything about a CVT filter either. Just looking for clarification in case I missed it.
michaelle8885 is offline
Old 01-19-2016, 09:13 AM
2014Maxima's Avatar
I would like to know about the CVT filter also. How many people here are actually changing them.
I was going to let the dealer do it, but they all want to do a complete flush. I really do not want to do this for fear this may cause problems with the torque converter or transmission. I have always heard that flushing is bad, and I can only imagine that it would be even harder on a CVT transmission.
I know that draining and refilling is not going to completely drain the system, but what methods do you all do to ensure that you can get as much of the old fluid out as possible?
Also, I have read that Nissan dealers somehow read the fluid and determine the life of it. How is this done, and is there something that needs to be reset for this after changing the fluid when doing it at home?
2014Maxima is offline
Old 01-19-2016, 10:51 AM
Richard66's Avatar
One way to get most of the old CVT oil out is do a drain and fill at the same time as an engine oil change and do this for three cycles. Depending on your millage this procedure would take somewhere around a year to complete, but
you will end up with mostly new oil. The upside is that it would not cost anymore than a dealership flush and you don't have to worry about damage that could be caused from a flush.
Old 01-21-2016, 11:07 AM
I just got my first fluid change after 110,000 miles. The dealer completed a tranny flush for me for about $225. My car feels so much smoother and acceleration and de-acceleration feel so much better. Regarding peoples comments on flushes hurting your transmission. Why do people think that dealerships would complete tranny flushes if it would damage transmissions and/or ruin their reputation of their transmissions? It just doesn't make any sense to me?
Old 01-21-2016, 07:01 PM
Maximam's Avatar
Chances are they removed and replaced the fluid.
Maximam is offline
Old 01-21-2016, 08:19 PM
innofish's Avatar
Wow! 310K for an 09 Max? That's a lot of driving.
innofish is offline
Old 01-24-2016, 11:57 AM
CorollaULEV's Avatar
The CVT filter is listed in Nissan parts as a transmission fluid cooler filter. If going to the parts desk, several dealers have told me "there is no filter on the transmission" - I guess just not looking it up correctly. Ask for tranny fluid cooler filter.
High pressure methods for flushing fluid out are not good. A true transmission flush would involve idling the engine, disconnecting the transmission fluid cooler return line and pouring fluid into the charge pipe while the car is pumping old fluid out and doing until fluid coming out is clear/new. It's nothing special and can be done at home.
CorollaULEV is offline
brichi
11-01-2015 06:40 AM
Brazy1482
10-23-2015 10:47 AM
ATDoel
10-20-2015 07:40 AM
AceVQ30DE
23
10-07-2015 11:08 PM
Quick Reply: General consensus on when to change tranny fluid?
