The BOSE Radio/Speaker Replacement thread
#762
Just replaced Bose HU in my '96 Maxima
Everything is working well, but I had a couple of questions. Thanks in advance for your answers.
1) I have a black ground wire coming out of HU, and a black wire and another black/white wire coming out of the harness. The Crutchfield guy told me to connect these together, which I did. Everything works fine, but I'm wondering if I need to connect these to the chassis. I understand from this thread that the Bose HU was grounded through its metal case. I imagine my new HU (Clarion CZ401) also has a grounded metal case, which I think would mean that my system is sufficiently grounded, despite not having a ground wire connected to the chassis. Am I right?
2) I have determined that the amp on my right rear speaker is dead. The speaker is still good, I believe. Would it be possible or advisable to a) bypass the Scosche amp interface (I wish I had seen this forum earlier and had bought the Metra one, but the Scosche seems to be working OK) and b) bypass the amp on the back of my rear right speaker, so that essentially the HU amp will be powering the speaker. Would that work or is the impedance wrong, or something else? If I swapped out that speaker for a run-of-the-mill aftermarket speaker, would this work?
Thanks!
Thanks!
#763
Hey all, I need some help or advice on my 2006 Maxima with the Bose system no Navigation. All of a sudden I have no sound coming out of my speaker. I went thru all the fuse in the car and all is good. I mean, CD/ Radio/Cassette, Screen, Bluetooth, etc is working, but just no sound is coming out. At first I thought the Bose amp took a dump, but when I it tested on my friend maxima, its was working in his car. But when I test hissed Bose amp in my car, it didn't work same result as my stock amp. So Im thinking it may be the factory Bose headunit. But I don't want to jump the gun and go buyme a $400 double din
#765
#769
hey, all. got an aftermarket hu for our i30 (97) that came with a nissan based harness (7550 w/o rca cables). the hu works, but there is no sound... can i re-wire it for the infiniti w/o buying the 7551 harness? (nothing local, and online will take 3-4 days at least). can i just buy some rca cables and wire them in?
11 and 12 on my small harness are just dangling in the air right now.
i'm also missing the #9 connector, it's just empty.
Smaller Harness:
16_______12
15_14_13_11
11 = Shield Wire Ground (ground wire runs with signal cables(+ and -) for rear BOSE amplifiers to shield their signal)
12 = Amp On Signal Wire (turns on all 4 BOSE amplifiers)
13 = Left Rear -
14 = Left Rear +
15 = Rear Right -
16 = Rear Right +
16_______12
15_14_13_11
13 = Left Rear -
14 = Left Rear +
15 = Rear Right -
16 = Rear Right +
Larger Harness:
10_8 ___4_2
9_7_6_5_3_1
1 = Front Left -
2 = Front Left +
3 = Front Right -
4 = Front Right +
5 = Power Antenna
6 = Battery (this ensures you keep your presets when your car is turned off)
7 = Illumination Constant (wont dim when lights are on, most cases you would use this)
8 = Illumination Switch (will dim your radio when your lights are on)
9 = Shield Wire Ground (ground wire runs with signal cables(+ and -) for front BOSE amplifiers to shield their signal)
10 = ACC/Ignition (the red wire)
10_8 ___4_2
9_7_6_5_3_1
1 = Front Left -
2 = Front Left +
3 = Front Right -
4 = Front Right +
5 = Power Antenna
#770
so i've wired the rcas and once plugged in i only get front speakers and the sound is weird - it's quite and there is popping in the speakers when you mess with the hu's settings.
once i unplug them - the sound is great. i'm sure i've wired the rcas correctly. haven't soldered the connections yet though.
i think the part i'm missing is the amp wire. if i were to use the bose amps, where does that wire go? since we're bypassing the hu's amp wire. i've grounded both front and back shield wires as well. any help is appreciated.
the hu i'm using: http://www.crutchfield.com/S-nI9O7HQ...ml#details-tab
says the preamp voltage is 2.2v. i've read earlier in this thread that you need the 7551 metra only if the preamps are greater than 4v?
edit: i guess, i'm an idiot lol i "forgot" that the amp wire that is coming from the hu is for a dedicated amp, in our case = bose. so, should i keep using the existing harness w/o rcas or buy a loc, since 2.2v isn't adequate?
#771
Here's a write-up on how to fix the speaker cutting out, by another member.
http://www.shiftice.com/bose_cutout_fix.html
#772
I'm in the process of pulling out the rear deck. I pulled out the rear seat/back, took all the screws/bolts/brake light/etc, but I think the rear deck is still held in by the 2 pieces of trim that are to each side of the rear deck.
Anyone have experience taking this off? I'm afraid of breaking something ><
#773
installed everything today (7550 w/o rcas). sounds good, except for the interference type noise coming from all speakers when nothing is playing. it gets louder when the volume increases also. noise sounds like a fm radio without any signal. i have not installed the antenna adapter yet. also, should the power antenna wire be wired up with the amp on wire?
thank you, guys!
thank you, guys!
#774
#775
thank you, guys!
thank you, guys!
appreciate any input.
#777
i'm not using rca's since the stereo already came with the 7550 kit, i believe. the po used it without any problems. i've tried wiring the rcas into the speaker wires, then hooking everything up like a 7551 model, but the sound was very low and there was popping everywhere. i don't think this stereo has enough juice (only 2.2v). it sounds goo enough, but if there is any danger to the stereo/speakers running it like that, let me know.
should i also wire the power antenna to the amp-on wire?
thanks, man!
edit: just remembered that i haven't hooked up the antenna yet, since i don't have the adapter for it. could the dangling antenna thing be the cause as well, if it's touching something metallic in the back? i tried to loop it around some wires, but it might have gotten loose and dropped.
#779
i've received everything on Sat. and began the journey lol
According to this diagram, there is no power antenna wire for this hu, but that wire is on the harness, according to the op's diagram.
#780
You didn't explicitly state the car has Bose, but I'll imply that you do, considering you were trying to purchase a Bose deck from another member.
I don't remember the last time I've seen an aftermarket head unit that doesn't have separate power antenna/remote turn on wires, and I don't see the diagram you're referring to.
But think of it this way. Power antenna is like a remote turn on wire, but only when the radio is in AM/FM mode. If there isn't a power antenna wire, there is no harm to use the remote turn on wire for both the power antenna and the amp, except if you have a motorized up/down antenna, in which case the antenna will always be up, even when not in AM/FM mode.
It's my wife's car. 97 Infiniti I30. I've contacted a member about purchasing his bose, but he also happened to have an aftermarket deck, which he said was plug'n'play. here is the hu: http://www.crutchfield.com/S-PIp0VBV...ml#details-tab
#781
here's the link to the diagram pic:
http://imageshack.us/photo/my-images...apturewmc.jpg/
taken from this pdf: http://www.pioneerelectronics.com/St...Manual1023.pdf
i don't think her antenna moves up and down any more, so i might just leave that wire disconnected.
aslo, according to this:
This harness is all well and good, but it is taking the raw power signal from your headunits internal amp and sending it to the BOSE amplifiers. This harness is geared for aftermarket headunits without 4 sepaker preamp out jacks. This method will work, BUT, you get alot of distortion because it's a high level signal. TOO much signal produces distortion, too little signal will prevent the volume from reaching a decent level. As I said before, this will work, but you will get a crappier signal.
thanks a lot for all your help, man!
#782
Well, guess you're right. No power antenna wire on this deck. Use the remote turn on for both - or just the one since the antenna doesn't work anyway, doesn't really matter.
The quote about levels is dead on, and is the CRUX of this very thread.
7551 won't help, Preout levels are too low. Assuming you do infact have Bose, you need an LOC. If you don't have bose, then straight speaker wire from the head unit into the 7550 is the correct way to do it.
sorry for being vague about the stock hu. thought all i30's had bose.
i should be getting distortion, but it plays nice. should i bother getting a 7551 harness at all? since my failed rca experiment, i don't think i should, since i would need to purchase a loc in addition to the 7551 harness to make up for the weak 2.2 preamp voltage. any harm running it w/o rcas like this?
#783
#785
#786
changing the ground location last night didn't help. still have noise from the speakers. it doesn't increase with rpm anymore though.
i did order the 7551 harness, slc-4 loc, and some other parts needed to get this done. will keep you updated.
#787
#788
Yo thanx for the link. Im going to read it now. BTW, I bought me a double din and guess wat???? Same F'ing results...I am so tired of my car audio. WHY ISN'T THERE ANY SOUND COMING OUT OF MY SPEAKERS!!!! Im about to lose it. Everything on the double din works, juss no sound. And now Im gonna go look up at that link.
#791
thank you, djfrestyl for all your help and patience
p.s. now i need to see why the antenna is not retracting. the power ant wire is hooked up to the amp turn-on right now.
#792
It's not retracting because the amp turn-on is on all the time. Nothing you can do about this.
If your HU had a separate power antenna wire, then it would only give power to that wire when the radio function is enabled.
Makes sense, right?
Makes sense, right?
#793
didn't know the amp turn-on was constantly on. i thought it worked only when the hu was on.
#794
#796
You're telling me your antenna is up even when the HU is fully turned off? Are you sure you don't have it connected to ACC or +12v?
#797
lol the antenna doesn't work, it's down all the time. that's what i've meant by not retracting
#798
#799
not sure if it ever worked since we got the car. i don't think it did. i'll do some troubleshooting later. thanks a lot, man!
