Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Suspension Setups [Auto-X]
Old 09-24-2011, 06:01 PM
  #81
jetsfanez's Avatar
every time i make a sharp turn, my whole body shifts in the car, any way for me to improve suspension. or its a suspension issue? I have KYB Shock adsorbers, but thats it.
jetsfanez is offline
Old 09-25-2011, 09:52 AM
  #82
Lightly modded
95maxrider's Avatar
I don't understand your question. But it sounds like you need this:
CG Lock
95maxrider is offline
Old 01-22-2012, 08:47 PM
  #83
mikerosey's Avatar
hi.. Some of the important steps to Follow..
hi.. this is rosey from A Plus Transmission Specialist Company..
This is some of the important steps to follow "Manual 6mt HLSD, NA"
1. Ko [.25-1.0f/.75r] want to stiffen rear
2. Ei Pro(Must to push and pull method)
3. FSTB, RSTB, RSw (removed FSw)
4. -2.5 degrees
5. now 42/32 (was 54/38)
6. now 225/50/16, 205/55/16 S-02's.
For clear clarification enter into our Texas transmission and Manual transmission repair.
regards..
Rose
A Plus Transmission..
mikerosey is offline
Old 07-20-2012, 08:37 AM
  #84
Lightly modded
95maxrider's Avatar
Well I finally got the car corner balanced and a proper alignment. It's a little aggressive for the street, but luckily I don't have to drive the car every day.
Nick, 1996 I30, Manual trans, NA
1. BC Coilovers, 9k Front, 8k Rear springs, usually run at full stiff (30/30)
2. Dropped about 1.5"
3. FSTB, RSTB, Stage 1 LTB, Stage 2 SFC, fender braces, panhard rod conversion, RSB
4. Street tires: 45f/45r, Hoosier A6: 35f/35+r
5. -2.0* camber and -0.1* toe out, ~2.8* caster
6. Street tire: 245/45/17 Michelin Pilot Super Sport, Race: Hoosier A6 245/40/17
Total vehicle weight with 160 lb. driver and almost full tank of gas is 3290, with a 60.0% Front/40.0% Rear split. 50%/50% side to side.
Old 04-11-2013, 06:09 AM
  #85
Lightly modded
95maxrider's Avatar
Time for a 2013 update. This time with added caster! Check my build thread for more info.
3. FSTB, RSTB, Stage 2 SFC, fender braces, panhard rod conversion, RSB
4. Street tires: 45f/45r, Hoosier A6: 42f/38+r
5. -2.5* camber and -0.1* toe out, ~4.7* caster
04-16-2020 05:15 AM
knight_yyz
11-01-2015 01:34 PM
JakeOfAllTrades
09-30-2015 03:16 PM
Quick Reply: Suspension Setups [Auto-X]
