1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Drag racing and staying COOL
Old Nov 18, 2002 | 02:38 PM
Burton069's Avatar
I was at the track, and it was around 50 degrees, which is nice and cool. I was wondering where the car would perform best in reference to the temperature gauge. Usually my car is right in the middle of H and C.
Old Nov 18, 2002 | 04:08 PM
SuDZ's Avatar
Re: Drag racing and staying COOL
That is about ideal. You dont really want to beat up on it before it heats up enough and you dont want your engine coming to a boil either.
SuDZ
Old Nov 19, 2002 | 07:42 PM
Cutler's Avatar
bags of ice are your friend
Old Nov 19, 2002 | 09:15 PM
Nealoc187's Avatar
SLOW
The temp guage is just the water temperature.
Old Nov 19, 2002 | 09:18 PM
Cutler's Avatar
Listen to neal, he is a master at this
Old Nov 19, 2002 | 09:55 PM
Aaron92SE's Avatar
NWP Engineering.com
It's always best to let your car cool down for a little while. I like my needle just below regular operating temperature when I launch it.
Old Nov 19, 2002 | 10:20 PM
Burton069's Avatar
Where should I put ice? just after the TB? I saw a WRX with ICE on the intercooler, but my car doesn't have that
Old Nov 19, 2002 | 10:45 PM
Aaron92SE's Avatar
NWP Engineering.com
Put it right on top of your motor. Keep it from dripping on your coil packs. It's best to lay it right on top of your intake manifold.
Old Nov 20, 2002 | 11:02 AM
DougsfastZ's Avatar
All Black Max
My Max makes the most power when it is almost dead cold.
Doug D
Old Nov 20, 2002 | 06:53 PM
Nealoc187's Avatar
SLOW
Put the ice on your intake manifold.
My comment about the water temp was just to illustrate that the temp guage doesn't tell you how hot the engine is, its how hot the water is. There's a correlation, but it's not direct.
The cooler the better, but at least make sure it's warm enough that the oil is up to temp. In a normal track day, it's probably good to have your car running for about a minute before doing your burnout or run, unless you've let your car sit not running for like 3 hours, in which case you'd want to get it a little warmer.
Old Nov 20, 2002 | 07:35 PM
ejj's Avatar
ejj
I've tried the ice thing, and found that it really doesn't help that much...plus its a pain to deal with the bag.
I also don't think that the water temp matter that much regarding times. I always make sure my car is up to temp. If you that worried about keeping your water temps down, you can wire a switch to turn your fans on when the car is off.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
magiconthetire
Oct 26, 2015 09:03 PM
leatherneck
Sep 30, 2015 09:16 PM
