1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Wheres the top end?
Old Dec 22, 2002 | 07:13 PM
MaxSpeedSE's Avatar
Wheres the top end?
Im looking at alot of the times for the 4th gen maxima 5 speed, and alot of them have awsome 60 foot times, and very low 1/8 times, but finished the 1/4 kind week...
Why are our cars so week top end, even with mods like Cat back exhuast, and Y pipe...
Old Dec 22, 2002 | 10:02 PM
PlanoSER's Avatar
b/c u dont have VTEC!! jk jk
Old Dec 22, 2002 | 10:15 PM
MaxSpeedSE's Avatar
Yeah well you would still figure a V6 would pull harder hen a 4 cylinder with close to the same power.... top end any day
Old Dec 23, 2002 | 09:34 AM
infinitiblast's Avatar
Get mevi...youll have better top end then.
Old Dec 23, 2002 | 09:37 AM
SonicDust187's Avatar
How much does it cost to install a MEVI?
Old Dec 23, 2002 | 09:42 AM
I'd say do it yourself..and you can see the prices for the mevi's in the group deal area. Imagine...30extra wheel hp at redline pull baby pull.
Old Dec 23, 2002 | 02:44 PM
MaxSpeedSE's Avatar
Yeah I'll have more top end...with a great loss of low end .....
Old Dec 23, 2002 | 02:46 PM
MaxSpeedSE's Avatar
Yes that is tru...but with th MEVI i lose a great amount of low end for the top end that i gain
Old Dec 23, 2002 | 02:49 PM
Jeff92se's Avatar
I'm needing a caw
Put that same v6 into a 4 cylinder body and then see the top end move up. Power to weight ratio
Old Dec 23, 2002 | 07:02 PM
Nealoc187's Avatar
SLOW
I'm curious as to how you are deducing from the 1/4 mile time that the maxima has weak topend? 1/4-1/8 differential? Before MEVI I gained about 20mph in the last 1/8th, now I gain about 21mph. 19-21mph is typical for a street driven car.
Also, why such negativity about the VI? You complained about not having top end but then the one real solution to get yourself more topend you scoff at...? Strange to me.
Old Dec 24, 2002 | 08:50 AM
MaxSpeedSE's Avatar
Becuase i dont want to lose low end... i felt like i was taking people low end and not beating them top end, but i dont want it to be fliped with a MEVI, where im getting beat off the line and pulling hard low end.....your sign says u run a 13.9 all motor...is that on street tires, and a 4th gen maxima?
Old Dec 24, 2002 | 11:30 AM
Nismo87SE's Avatar
slicks, MEVI, ypipe, intake, weigh reduction. If he had a jwt ecu he could possible hit 13.7-13.8s @ 99-100mph.
Old Dec 26, 2002 | 12:26 AM
Dev's Avatar
Dev
then why don't you get a supercharger? that will increase power throughout the rpm range...high and low.
and how are you comparing to say maxima's have bad high end?
i think the high end is pretty good. i was trapping an average of 94mph with a jwt filter only.
and that was with crappy launches of 2.4's
Old Dec 26, 2002 | 10:02 AM
Nealoc187's Avatar
SLOW
It's true on the dyno I did lose some low-midrange punch. How much this will affect you on the street or the track depends on your driving/racing habits.
I believe that at the track it does hamper you a bit. In the low-mid range I lost power, at 3400 I went from 185ft-lb to 168ft-lb, and at 4800rpm I went from 189ft-lb to 172ft-lb. However, even in the 1/8th mile, I am now trapping higher than ever. Over 77mph consistently, almost 78 on occasion. So even with the torque loss, in the first 9 seconds of the race, I'm already going faster than I was before. After that, things just get better and better. It's effect on top speed is phenomenal. Prior to the MEVI I could get to 6000rpm (indicated) in 5th gear, now I can get to an indicated 6500rpm in 5th, the high end charge this mod gives the car is phenomenal. If you want more top end this is the mod to get (for the price).
Old Dec 26, 2002 | 11:40 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
From my sig...
The USIM will give you better around-town peppiness, and give you better off-the-line performance. But the USIM makes the VQ fall flat on its face at the top-end, so you're very limited in highway pulling power.
The MEVI is the exact opposite. Superior top-end, but not as much low/mid-range. But highway pulling power is increased phenomenally. You have to shift the USIM VQ into 5th at around 5600rpm if you want to keep moving. But with the MEVI you can hold 4th all the way to the limiter, and then hit the limiter again in 5th if you have enough road and pull a significant amount on a USIM Maxima.
Old Dec 26, 2002 | 12:25 PM
Originally posted by SteVTEC
From my sig...
Whats the top speed with the MEVI?
Old Dec 28, 2002 | 11:28 PM
MaxSpeedSE's Avatar
What about products like the ECU upgrade, do thoes giver gains threw the whole power band? anyone have dynos on that?
The MEVI intake is nice, i just hate losing some for gaining some...
Old Dec 30, 2002 | 09:10 AM
dmontzsta's Avatar
Ford Only.
here is where I chime in...
GOT VE?
Old Dec 31, 2002 | 12:23 AM
Dev's Avatar
Dev
im guessing you're looking to improve your car's performance in a racing situation...?
well if thats the case, when you're racing, you shouldn't be in low-end rpm range at all.
other than the launch, you should be above 4000rpm give or take.
so the MEVI would be very beneficial, since low end isn't really too much of a factor when racing.
Old Dec 31, 2002 | 12:56 AM
nismo2020's Avatar
Needs non-Maxima Friends
GOT VE?
nope, sure dont
Old Dec 31, 2002 | 05:28 AM
Our cars have more then enough top end, if we didn't I would have not been able to take a 3.5 214hp Intrepid on the highway.
Old Dec 31, 2002 | 10:53 AM
Nealoc187's Avatar
SLOW
A shining example of why peak #s mean nothing.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Sep 27, 2015 08:37 AM
