1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Some links needed for drag racing help
Old Mar 9, 2003 | 04:01 PM
MardiGrasMax's Avatar
Are their any sites that can predict what rpm I will be at in 4th gear with a certain diameter tire, or what size tore I need to not have to shift out of third but still run 120mph?
Are their any forums for hard core FWD races to discuss suspension set ups?
Old Mar 9, 2003 | 04:18 PM
Jime's Avatar
Re: Some links needed for drag racing help
Matt, you don't need any help.
Most of the hardcore guys I know are DSM and of course their suspension requirements are totally different from ours.
Here is where I got the idea for my suspension mod. I has some good stuff.
http://www.cnw.com/~redline/launching.htm
Old Mar 9, 2003 | 05:56 PM
Re: Re: Some links needed for drag racing help
Help, well perhaps mental help
I was looking at my rear coils and I cant figure for the life of me how the heck you get those inserts in their and wraped around the strut shaft? I have Eibach springs maybe the coil spacing is tighter than what you have, what springs do you have?
I am considering somthing like welding a set of stock struts fully extended to jack the back up and get zero squat. But it will be a pain to swap out rear strut housings at the track.
Maybe air bags? Or do they make air struts for coil over set ups? I'm looking for a way to firm up the back and rais it up whick dosent involve too much work at the track?
Old Mar 9, 2003 | 06:06 PM
Jime's Avatar
Re: Re: Re: Some links needed for drag racing help
I had to cut off the dust covers, I have stock struts and Maxspeed Springs, its fun to get them in there and I now take the rear wheel off to do it vs jacking up and crawling under.
I am thinking about making a bracket for the top and bottom that extends out towards the center just past the spring and then just bolting a solid rod between them at the track. You are right though gotta be an easier way. I'll let you know if I come up with an easier method.
I tried chaining the front down too but didn't seem to help much like the rear did. Makes a rough ride on the return road though with the rear rigid.
Anyway I am still looking at an easier way, some morning I will wake up with a better idea, I hope.
Old Mar 9, 2003 | 07:57 PM
Cincy94Max's Avatar
Here's some of the info I have amassed:
http://myweb.cableone.net/bcanderson...ils/coils.html
http://www.sardesonracing.com/spring_access_.htm
http://www.secureperformanceorder.co...ProductID=4542
http://www.jcwhitney.com/productnoit...=14833&BQ=jcw2
http://www.dsmtalk.com/forums/showth...light=zip+ties
http://www.galls.com/shop/viewProduc...jsp?item=RS099
http://www.discounthandcuffs.com/monsparcufdi.html
http://www.staginglight.com/
http://www.maxdes.net/how2makelight.html
http://pages.cthome.net/gus/traction.html
VHT distributors:
http://www.caswellplating.com/vht/vht_quality.htm
http://www.beardenoilco.com/products.jsp
tire calculator with engine rpm:
http://gs.tolan-hoechst.com/tirecalc.htm
Old Mar 10, 2003 | 07:21 AM
Thanks Cincy, good stuff!
I like the zip ties, thats crazy, but prolly effective. and 3/4" spring spacers, thats got me written all over it!
Old Mar 10, 2003 | 08:56 PM
Cincy94Max's Avatar
No problem. Those ideas, combined with some others I have, should get my VG auto into the 16.1 range and possibly the 15's this summer without using any power upgrades. If the ideas can work with my anemic 120 or so HP, I'm sure they can work with your gobs of HP and help you reach your much more noble goal of 11's. If I find anymore info, I'll send it your way. Have a good day.
Old Mar 13, 2003 | 11:15 PM
Aaron92SE's Avatar
NWP Engineering.com
I'm serious, that's a good idea. I should hang around DSM forums more often. So, I need the spacer shown here: http://www.jcwhitney.com/productnoit...=14833&BQ=jcw2
And some nice tie wraps to hold my front from coming up. Dude, that is awesome. That has got to be the worst problem I have with my car. My front end rises SOOOO much on the launch. I am always looking for cheap mods. I thought I ran out of cheap mods, but I just found another. Muwahaha!
Old Mar 14, 2003 | 06:33 AM
gtr_rider's Avatar
192.168.1.1
I learned a lot in that link, thanks Jime
Old Mar 14, 2003 | 10:51 AM
96sleeper's Avatar
http://www.smokemup.com/auto_math/mph_range.php
You can enter in your tire size and gear ratios and it will give you MPH at every rpm through the band. Check out the rest of the auto math on the page too, you can enter in two different tire sizes and compare them.
Old Mar 14, 2003 | 11:16 AM
Cincy94Max's Avatar
Anytime you need some mental stimulation, just go and read the DSM threads in the Advanced Discussion area over at www.dsmtalk.com . Those guys know their stuff and do some crazy stuff with it too. They've been going fast since 1990 and their knowledge base is huge.
Old Mar 14, 2003 | 11:22 AM
Looks like I'm good till 130mph in 4th. To stay in 3rd I would need a 30" slick for 120mph traps with a 6500rpm limit.
Old Mar 28, 2003 | 06:44 AM
Chinkzilla's Avatar
hmm, i'm praying my JIC coilovers will shave off a few tenths with the proper set-up.
I was thinking of preloading my rears all the way up, and setting the stiffness to 8.
If I really wanted to get extreme, I could drop the fronts all the way down and raise the rear all the way up.
just some thoughts
Old Apr 5, 2003 | 01:05 AM
SR20DEN's Avatar
VQ Wizard
http://www.smokemup.com/auto_math/index.php
Old Apr 5, 2003 | 01:12 AM
SR20DEN's Avatar
VQ Wizard
I have the perfect ty-wraps at work for this. I'll get pics and part numbers on Monday. They're over 3/8" wide 18" long and reusable.
Old Apr 7, 2003 | 12:54 AM
Aaron92SE's Avatar
NWP Engineering.com
PLEASE let us know. I am interested.
Old Apr 7, 2003 | 01:43 AM
Aaron92SE's Avatar
NWP Engineering.com
Oh yeah, how exactly would you install these zip ties? Would you only wrap it around the two spring coils that are closest to each other? Or would you skip a row and wrap it around more than 2? I hope this makes sense.
Old Apr 8, 2003 | 10:13 AM
SR20DEN's Avatar
VQ Wizard
Panduit
DIA: .5"
Length: 20"
UPC 07498354201
Part# PRT5EH-C0
http://www.panduit.com/newutils/cats...egin&PNS=PARTN
Tinsel Strength 90 lbs.
These thigns are re usable too.
You can get them from any Telco supply place.
If you absolutely can't find them let me know and I'll get them for you.
Old Apr 8, 2003 | 01:04 PM
Aaron92SE's Avatar
NWP Engineering.com
So, since it's 20" in length, I guess you can wrap it around the coils atleast 2 times?
How many would you use? One on one side of the spring and one on the other?
Tinsel strength is 90 lbs? Is this the same thing as saying the police tie wrap handcuffs hold up to 500 lbs?
I need these... what is a Telco supplier? I've never heard of that.
Old Apr 8, 2003 | 01:14 PM
SR20DEN's Avatar
VQ Wizard
You don't have to get them in 20" lengths. Cut them shorter if you want.
How many would you use? One on one side of the spring and one on the other??
I plan to use four in either 180º or 90º increments.
Tinsel strength is 90 lbs? Is this the same thing as saying the police tie wrap handcuffs hold up to 500 lbs??
Thats just a rated number. The lock is probably the weak point. I expect these things will hold alot more than 90 pounds.
Telco = Telephone Company
Old Apr 8, 2003 | 03:07 PM
Aaron92SE's Avatar
NWP Engineering.com
Thanks SR... now I just need to find if I have one in my area.. Las Vegas. I know we have an industrial supply store called Fasco. I'm sure they will have something.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Team STILLEN
Aug 10, 2015 04:29 PM
mikekay
Aug 10, 2015 12:52 PM
