1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Very disappointed time at track
Old Jul 8, 2003 | 02:37 PM
SLOW96MAX's Avatar
I have a 96 gxe auto with pulley, intake, y pipe. I went to the track and my best time was a lousy 15.7 at 88mph with 2.48 short times. Shouldn't I be running quicker and with a better mph?
Old Jul 8, 2003 | 02:40 PM
Y2KSESteve's Avatar
What was the temperature when you ran? Warmer temperatures and higher humidity can hurt your times.
Old Jul 8, 2003 | 10:19 PM
BadKarma99-4spd's Avatar
did you check your ecu for any trouble codes, the knock sensor supposedly robs a lot of power
good luck
Old Jul 8, 2003 | 11:23 PM
Max Noob's Avatar
practice your launch.. its auto.. kinda tricky
Old Jul 9, 2003 | 08:31 AM
SLOW96MAX's Avatar
Re: Very disappointed time at track
It was like 85 degrees. I launched at 1200 rpm using the ebrake.
Old Jul 9, 2003 | 08:51 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
You're not going to run well if it was 85F out, especially if there was humidity as well. Considering your 60' time, that's honestly not a bad time given conditions. If you improved your launch to a 2.40 that would have been about a 15.5 @ 88. In better weather you should be able to get into the low-15's at maybe 90 mph.
Old Jul 10, 2003 | 09:16 PM
MaximaPower's Avatar
i think it's too hard to compare times with other people on the org. i think the only way is to compare with some maximas at the same track, that ran in the same conditions u ran.
btw, i have a 99 auto stock, and i ran 15.77@87.3mph with a 2.426 60'last sunday...so u should be alot quicker than i am
Team STILLEN
Aug 10, 2015 04:29 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
