1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
What should I set my KYB AGX shocks at 4 dragway ?
Old Aug 6, 2003 | 08:38 PM
Ceasars Chariot's Avatar
Old Maxima Legend
Hey, didnt know if it even mattered but I got to thinking. What are people with KYB AGX setting their front shocks at ?
thanks people ..I have some Toyo TI-S's on the way. NEW RUBBER ! I will be heading back to the dragway to try for 14.9 again in the CHARIOT ! Wish me luck or pay pal me some cash for driving lessons !
Old Aug 6, 2003 | 10:28 PM
Dev's Avatar
Dev
hey
it would probably be wise to set the agx to 4/8 for the front and rear respectively. you obviously don't want the rear sagging on the launch, so keep that as stiff as possible, plus you don't want the front end to raise - for that i say 4 because it is also adjustable for rebound (so i hear on this forum).
good luck at the track...the new rubber will definitely get you into the 14's
Old Aug 6, 2003 | 10:56 PM
Old Maxima Legend
Dave B's Patented Shift Technique
Dev, im holding you to that prediction !! Im going to try the patented Dave B Shift Technique also.
1-2. 6500
2-3. 6100
3-4. 5800
If this doesnt work, then back to mine:
1-2. redline
2-3. redline
lol...! Also Im thinking about taking out the backseat. Would cut another 30 pounds. But then again, that seems like cheating.
Old Aug 6, 2003 | 11:25 PM
Dev's Avatar
Dev
i tried that shifting into 4th stuff last time...and my traps only peaked at 94mph (with ypipe)
last time i redlined every damn gear, and crossed the line in 3rd, my traps peaked 95mph (without ypipe)
next time i go...i stay in 3rd
Old Aug 7, 2003 | 07:31 AM
I30tMikeD's Avatar
You have been shifting at redline on each shift. That's a a big no no with the stock manifold. Although I think it should be more like 6500, 6200 6000.
Nothing at the track is cheating. Do what ever you can to run the best time you can. That's what it's all about.
Old Aug 7, 2003 | 08:14 AM
Nealoc187's Avatar
SLOW
Adjusting the settings on AGX shocks adjusts the rebound only, not the bump. It will make no difference whatsoever in your launch. I run the same time with them set on 1 as I do on 8.
Old Aug 7, 2003 | 04:59 PM
aznsap's Avatar
i would like to know where nealoc shifts @ in each gear, as he does have the fastest na 4th gen.
Old Aug 7, 2003 | 08:38 PM
SonicDust187's Avatar
I belive he uses the 1-2 @6550
2-3 @ 6200
3-4 @ 6000
Old Aug 7, 2003 | 09:53 PM
Dev's Avatar
Dev
hmm...i've heard otherwise, but don't own a set to back up my point.
i've heard that its adjustable for compression as well as rebound.
it probably doesn't affect you as much because you have stiff a$$ ground controls which already reduce weight transfer
aznsap, nealoc will have different shift points because he has a MEVI and JWT ECU which has a raised rev limiter to 7200.
without that, you cannot shift at the same points that he does.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
