1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Race gas didn't help my trap speeds at all today with JWT ECU and MEVI
Old Apr 17, 2004 | 06:48 PM
Nealoc187's Avatar
SLOW
Today was the worst day I've ever had at the track, I haven't run this slow in about a year and a half, but anyhow, I did come to the conclusion that at least for my car, race gas does nothing.
It was hot as hell and EVERYONE was running very slowly.
I made one pass right when I got there, at probably 76 degrees or so, before I put in any race gas. I trapped 98.15mph, that was my highest trapspeed of the entire day
Then I mixed in 2 gallons of 104 with probably 4 gallons of 93, resulting in about 97 octane. I never broke out of 97mph traps until my last pass of the day, and I made about 10 of them. also my ETs were because I couldn't hook up for the life of me, I've literally never cut 60's in my life. My best of the day was a 2.25, that's usually my worst. Most of them were right around 2.30 with some as high as 2.38 wtf. Anyways, best ET was also on that first pass of the day (2.28 60') 14.30 @ 98.15 and it just went downhill from there.
Like I said everything was running way slow today. Mike was only trapping like 95-96, Modded evo trapping 97, wrx STI trapped 99, blown 99 mustang 5spd trapping 105, and brians bike was trapping 122 when it should be trapping around 126. so yeah today at the track sucked but the point of this thread was that race gas didn't do anything for me whatsoever, just a waste of $10 which could have gone towards my turbo or some food because I haven't eaten anything but a sandwich all day.
There were a number of max guys there and it was good to see you guys again, and to meet the guys I had never met before.
Old Apr 17, 2004 | 07:02 PM
Ceasars Chariot's Avatar
Old Maxima Legend
well this just sucks ! im all ready for trying some race gas , bought a 5 gallon jug, and some other stuff. this report doesnt sound to promising, but i guess im going to give it a shot as well.
im gonna try mixing 20-30 miles away and reset the ecu or something, not really sure what im going to do.
what is up with first pass best pass ? this has also been happening to me. its like going to vegas and gambling. you make one pass and keep trying to hit another jackpot but it never comes. as of late this has been happening to me. ONE AND DONE !
good to hear you got out and made some passes though. i was all set for sunday and the front left wheel bearing is shot ! so im sitting home !
neal, 14.30 ? lol look out , your in chariot territory !
Old Apr 17, 2004 | 07:58 PM
BEJAY1's Avatar
Conecarver
Good feedback Neal. I've got some Toulene and I'll try some dyno's to validate what you found.
Old May 3, 2004 | 02:55 PM
4dscKlr's Avatar
why would you even condider running race gas?
unless your under high boost applications, or are running a srious;y aggresive timing curve you will only LOSE power by running a higher octane. the higher the octane the slower it burns in your combustion chamber. thats why high compression / boosted applications need to run premium (91-93).
IF, IF, IF .................
you run race gas in a vehicle tuned for pump gas then you will gain nothing and more than likely lose HP.
if you get second tune (dont know how you maximas tune your cars) like a flip chip or something then race gas may benefit you. this is why you can easily foul your plugs too with too high of an octane... NOT NECESSARY....
like i said ... if your gonna run race gas get a second tune.. a street tune and a race tune... any reputable tuner should be able to do this
Old May 3, 2004 | 03:54 PM
Old Maxima Legend
i dont know much about it, most of the guys have the upgraded ecu's, and even with 2 gallons of 93 and 1 gallon of 100 you looking at approx. 95.3 or something close.
i wanted to experiment with it due to my upgraded ecu causing a bit of engine ping on chevron 93. my thinking was mixing the octane at times or using octane boost would help combat the problem. it seems to work but again just started messing with it. any thoughts?
Old May 3, 2004 | 05:04 PM
Nealoc187's Avatar
SLOW
Why would I consider it? I'm using an ECU which has been known to, in some cases, increase ignition timing to the point of preignition, that's why. A few people running my setup, including my good friend mike, who has identical mods to me, sees a night and day difference on race gas. He gains 2mph when he runs with a few gallons of 104 octane mixed in, and it works like clockwork for him. He gets to the track, runs with 93, and then mixes in a few gallons of 104, and viola, he's 2mph faster.
Also, I certainly didn't lose power, as I didn't run any slower the two times I ran it, I just didn't run any faster this time either.
Old May 3, 2004 | 06:44 PM
4dscKlr's Avatar
if your detonating then yel youll benefit.....
if not then it will not benefit you... higher octane is not higher performance, it just allows more of an aggressive tune....
as long as you understand that then good luck, and i hope you find your problem
Old May 3, 2004 | 07:03 PM
I30tMikeD's Avatar
I don't think he has a problem, he has the fastest known NA maxima.
I have close to 100 passes with my advanced timing ECU and running 96ish octane makes all the difference for me.
Old May 4, 2004 | 10:06 AM
deezo's Avatar
I've run 1 second slower in high humidity, was that the case today?
Old May 4, 2004 | 03:38 PM
Ferbs02SMMax's Avatar
We had a stifling heat that day, dry heat, not humid in the first four hours I was there...No wind, the heat was pretty bad. 1st run of the day I had a 94mph trap, with 76 degrees registering, so that either means it was either 74 or 78 degrees (Nissan therm is off -/+ 2 degrees)...My 2nd run, after I finally got back around, I trapped 93mph, and by then it was 82 degrees, and I had been sitting in the heat for over an hour.
Weather plays a big factor guys, it wasn't an optimal day to run. Not to mention track prep wasnt really stellar that day...
Matt93SE
May 24, 2019 02:58 PM
Slamrod
Sep 3, 2015 07:38 PM
t6378tp
Aug 24, 2015 07:03 AM
3rdmaxse0
Aug 18, 2015 08:25 AM
Trin1j23
Aug 12, 2015 08:31 PM
