1st time running at track
I ran at the track for the first time today. I ran 4 times then it got rained out, but my best was a 15.6almost 15.7, but i spun pretty bad off the line. It was about 87F outside with real high humidity. But it was fun, i know i could hve gotten my times down more if it would have been rained out. Here is the best time, which was also my best mph's.
RT .... .161
60' .... 2.455
330 ... 6.678
1/8 ... 10.156
MPH ...70.38
1000 ...13.160
1/4 ... 15.698
MPH ... 88.71
RT .... .161
60' .... 2.455
330 ... 6.678
1/8 ... 10.156
MPH ...70.38
1000 ...13.160
1/4 ... 15.698
MPH ... 88.71
looks like you had a go of it off the line with that 2.4 , but you did pretty good. you know that 60 will only get better as you visit the track more, so with some practice and a cool day at the track low 15's are in reach.
are your tires stock or aftermarket ? i forget about the 01 models if you guys had 15's or 16's .. try swaping your stock rims if you are running larger aftermarkets.
will you be going back or one and done ?
Oh i will definitly be going back, i had a great time though i only went 4 times before it started storming. My brother came down a liitle after me with his 99 s/c max but he couldnt run b/c of the rain. My wheels are the stock 17's. What kind of 60' should i be getting bone stock? Also on the those runs i didnt lower my tire pressure at all cause i wanted to get on the track asap before the storm so they were at 44psi, and they are the Michilin(sorry for spelling) sport a/s, great tires by the way. Thanks for your replies.
Hey who is your brother...is he on here? Also what track did you go to? I am asking because I am in charlottesville and I tried to come up there last week but turned around at short pump because it was raining so hard...I am going to try to make it back over there on friday if its not raining.
Ya i think ive met you at broad street maybe, or at least i think he knows you hes got the Silver 99 with stillen kit and momo wheels, and supercharged of coarse.
Drop your tire press down to 26-27psi(don't drop below 25psi or you may get shudder) & do a dry burn out and that should help you get your 60' times down to the 2.3 range or maybe even better. Good luck and have fun.
Dave
02 Maxima SE (AT)
Best 60' 2.294
Best ET 14.97
Best MPH 92.6
Dave
02 Maxima SE (AT)
Best 60' 2.294
Best ET 14.97
Best MPH 92.6
Don't do a burnout just spin them really quickly to get any rocks off them that might be stuck to them. Good 60' times come with practice generally. You should be able to get it to about 2.25 without much problem
ok, so your brother is "vortechpower" I dont think I have me you though...I will probably be in dinwiddie in a few weeks so I will let you guys know.
Team STILLEN
Aug 10, 2015 04:29 PM
julian888
Aug 6, 2015 04:39 AM
