1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
First time at the track with my S/C
Old Jun 29, 2004 | 08:48 AM
MAXimumHP's Avatar
This was only my second time to the track, I went once when I was stock. Even with my crappy driving I was satisfied with the results. I also had a completely full tank of gas. I didn't realize I would be going, and filled up the day before. The needle was above the "F". I did no weight reduction either, basically went as I drive it everyday. Didn't bother to lower the tire pressure. My 18's probably aren't helping me much either.
I don't have the slips, but I ran a 14.4 at about 100 mph. My 60' er's sucked, my best was 2.5 something. I really need to learn how to launch better. Any tips would be helpful.
My set-up is a Stillen S/C, basically as it comes from Stillen, stock 3.6 pulley, Stillen pancake filter, etc. The only other real power adder is the Budget Y-pipe.
I'm thinking I should be able to get into the 13's pretty easy just by learning to drive and remembering not to fill my tank the day before. I could also do some other simple things like adjusting my pressure down a little from 40psi and stuff.
Old Jun 29, 2004 | 08:58 AM
I30tMikeD's Avatar
That is a decent time for the stock pulley and a bad 60'. Could you post the whole slip when you get to them? Way to go!
Old Jun 29, 2004 | 09:10 AM
MAXimumHP's Avatar
Thanks Mike,
A 100mph trap should be good for a 13 sec run, right?
Also, for S/C cars I was assuming redline shifts are the optimum points, anyone know?
Old Jun 29, 2004 | 07:21 PM
I30tMikeD's Avatar
Originally Posted by MAXimumHP
Thanks Mike,
The car should be good for 13.9-14.1 assuming you can get out of the hole. I do believe that with the SC redline shifts are what you want.
Old Jun 30, 2004 | 05:29 PM
Ceasars Chariot's Avatar
Old Maxima Legend
give it a few more trys ! nice job !
Old Jun 30, 2004 | 06:28 PM
dmontzsta's Avatar
Ford Only.
Slick it up and knock down some easy 13s, not bad base times, they could be worse.
Old Jul 2, 2004 | 06:49 AM
Ferbs02SMMax's Avatar
That's a nasty trap speed. Nice strong running supercharged Max SEL.
Any pics of your car/setup please.
Old Jul 5, 2004 | 06:41 AM
bigdo26's Avatar
100 trap shows you're making some good power. 13's are yours with the right launch (and maybe a lil less gas in the car). Enjoy the blower!
Old Jul 6, 2004 | 09:16 AM
MAXimumHP's Avatar
Thanks for the comments guys. I think for the remainder of this year I'm just going to practice my launches at the track. When I get to low 14's or 13's, I may put a smaller pulley on. I'm also planning to get an MEVI in the future. But for now I really want to concentrate on learning how to drive what I got. To save my pricey S-03's, I may get some steelies and run some drag radials though. Ferbs, you can look at my homepage for some info, but I need to update that thing soon. Mike, I'll post the slip if I can ever remember to take a pic of it while I'm at home.
Eric
Old Jul 6, 2004 | 06:48 PM
SR20DEN's Avatar
VQ Wizard
Shift don't lift
Old Jul 6, 2004 | 07:02 PM
I30tMikeD's Avatar
you don't have to post a pic of the actual slip, I was just curious about the 1/8 mile and such.
Old Jul 7, 2004 | 08:15 AM
MAXimumHP's Avatar
Originally Posted by SR20DEN
Shift don't lift
While spinning in first?
Team STILLEN
Aug 10, 2015 04:29 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
