Mazda Millenia wheels (15X6)
Originally Posted by 95CustomMaxima
I connected it between the o2 sensor and the harness. I noticed the colors were different after the harness, like purple and such. I though you had it wired to your 4th gen before too. Do you happen to know what colors where the ones you spliced into in the ecu?
Thanks,
-Nick
Thanks,
-Nick
Presently I have the simulator disconnected and no CEL.
hey,
post in the DC local section...this is the same thing I am doing and I know there were other people that wanted the other two as well...but I only had enough for one other person....I think Redmax wants two, check with him
I got mine used with no centercaps....the reason for this is because, I don't need the center caps, and the center caps sell for around 40 bux each on ebay, so this is a cheaper way to go...no center caps
Did you buy them used or new?
NEAL:
>>if you already have to shift into 4th and are not planning on MEVI and JWT ECU then yes i'd go with that size. if you are planning on getting mevi and jwt ecu then things get more complicated.<<
I know you'd be in the power band longer with 26 inch tire if you have the MEVI... but you'd still have the quicker acceleration. Wouldn't that be fine with if you can get the traction to the ground.
NEAL:
It's not about being in the upper RPM longer its about not having to shift into 4th gear. Shifting loses time. I think you'd lose more time with a shorter tire and wasting time shifting than you would with a taller tire that you don't have to shift 3 times.
Originally Posted by JClaw
Then why are you suggesting a smaller tire for near stock cars? We're still gonna lose the time shifting...
Stock or near stock cars have to shift into 4th anyways... so why not have the gearing advantage also?
K... I was planning on getting a full cattman setup (headers/ypipe/highflow cat/catback/CAI) as well as lighter wheels for 2005 (that should put me deep in 14-second territory, wouldn't you think?)... maybe mevi/ecu/slicks but thats 2006 or later...
I'd get Ypipe ECU and MEVI before I got all that other stuff personally, and skip the high flow cat entirely. Ypipe ECU and MEVI and a simple filter on a stick should put you in low 14s if you can drive.
Problem is, most of my exhaust system is gonna have to be changed in a matter of months, so I don't have much of a choice for now. Plus, since I'm planning on getting the whole thing eventually (before or after mevi), might as well do it now. I save about 200US if I buy everything together.
Thanks for the reply, but im asking cause i already bought them so im looking for a tire that fit correctly (mazda millenias 15x6"), i would like som DR's cause my max is not that hardcore to use slicks. Thanks in advance for your help
225/50/15 G-Force DR's
I30tMikeD thanks for the advice i was about to buy a brand new pair of BFG DR's as you said, but since yesterday a friend of mine is offering a pair of BFG DR's 2nd gen for $160 (used of course), but they are 235/60r15 will they fit the millenia wheels?
PD: excuse me for the newbieness
Try this link: http://www.tirerack.com/tires/Spec.j...+Drag+Radial+2
Those tires fit a 6.5"-7.5" rim, so they should mount up OK... Good luck.
Andy29
Sep 29, 2015 05:32 AM
