My Mods = Low 14s?
My Mods = Low 14s?
I have a intake/ypipe/catback exhaust/hi-flow cat/underdrive pulley and Im about to get a Technosquare ECU
Im wondering if I can get into the low 14s with my 96 Auto GXE
Im taking out the rear seats/spare/jack...and I weigh 165 lbs (if that helps
thanks guys!!
)thanks guys!!
hmmmm
a 60-65 shot could actually put me in the high 13s
While racing in the track, when would I spray....at every gear?
I just dont want to go through the hassle of always filling up the bottle
now Im beginning to rethink if I shouldve gotten the ECU at all
Originally Posted by slammed
hmmmm
thanks guys!!
)thanks guys!!
More dieting( the car that is) and VI/ECU combo couldn't hurt either.
Originally Posted by JClaw
Neal is one heck of a driver to do 14.5 stock with 190 hp in a 3000 lbs car, so to do 14.5 in a stock auto 3.0 would be
i have all those modds well had those on my 95 gxe auto including mevi and still lost to a 2004 tsx acura stock 5 speed and when he did his 1/4 his best was a 15.6. i doubt you will be in the 14's unless you get that ecu. thats the major upgrade that will help you and the y-pipe. i was highy upset when i lost maybe thats why i hunted that 5 speed down now im ready and i think i can even beat him stock.
Originally Posted by Mass_Media
but I do remember seeing something that you could buy where you could tell it when to start and when to stop (WOT 4000rpm's to 6500rpm's after first gear) or something like that...I don't remember where I saw it though...
Window Switch... Worked great for me.
Just a suggestion if you get a window switch get the MSD 8969, its digital and doesn't require pills, you just set the on and off rpm points, very easy.
Its approx $5 more than the other type and you don't have to buy anything else or get it modified to run on a coil-on-plug setup. It has a digital display that shows RPM as well.
if u lost to that car that ran 15.6 somthing is wrong with ur car i hit 15.2 before the trannycooler and the rest of the tune up stuff i did , o i also have better tires now.somthin had to be wrong with your car
