1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Best street tire 60 foot (slight update)
Old Aug 1, 2005 | 09:00 AM
JClaw's Avatar
They started this stupid new rule at the track that the street class is 14.00s and up (there used to be a sport compact class, you could run 13s no problem, but it wasn't popular enough).
If you run 13s you go with the semi-pro class (Mostly V8 guys running 12s, 11s or 10s. Basically the class Jime races). I don't feel quite ready for that so I didn't bring my slicks and just kept the street tires. Even then I can run 13s but it's easier to slow down to 14.0 than it is with slicks. It's the first time I race with the traction bars & street tire combo.
After a f*cked first run (2.55 60 foot lol) and a so-so 2nd run (2.23 and 14.08@102) I settled to launching off idle as I usually do, and that did the trick, all weekend long the car would pull only low 2.1's and high 2.0's. The best was a 2.083. I have maybe 15 timeslips with 2.13's, 2.12's, 2.11's. 2.10's, 2.09's and 2.08's. A slight burnout seems to help.
Best run (first 1/8):
R/T=.013
60'=2.083
1/8=8.843
1/4=14.071@76.24 (to avoid breaking out)
Best run:
R/T=.025
60'=2.136
1/8=8.918
1/4=13.717@103.61 (they warned me after this one and this was the last (and only) run in the 13s)
Would be interesting to see what it pulls in a full all-out run. What I like about street tires is that I cut good reaction times, as opposed to slicks, where it's a hit or miss situation. Maybe it's time to run with the big guys...
I have Yokohama all-season Avid's, 215/60/15 on sawblades. 25 psi.
4th elimination round against a 12-second turbo civic (below) that was doing two classes (12.44 dial-in for the semi-pro class, and 14 flat for the street class). He was basically cruising, just keeping steady a little ahead of me. Beat him at his own game by flooring it completely for most of the run (thus certainly going under my 14.00 dial in), and then slamming on the brakes to a 14.02. He went under by .04.
Old Aug 1, 2005 | 03:21 PM
Nealoc187's Avatar
SLOW
Jeez that's a heck of a 60' for street tires, the best I've heard of actually. I know someone that pulled off a 2.09 but that was only once I believe. And yes that rule is retarded.
Old Aug 1, 2005 | 03:41 PM
JClaw's Avatar
Thanks. I actually pulled 2.08 3 times during the weekend so I doubt it's a fluke. I think it's possible to do a little better with ideal track conditions.
Old Aug 1, 2005 | 04:56 PM
Nealoc187's Avatar
SLOW
That's low end torque for ya. My best 60' ever is 2.16, and I've only done that once. I've pulled 2.17 a couple times and 2.18 lots of times though.
Old Aug 1, 2005 | 07:42 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah, I can only get 2.0s with drag radials heated up. The best I have gotten with normal street tires is low 2.2s. Great job!
Old Aug 1, 2005 | 08:48 PM
JClaw's Avatar
It will be interesting to see if they simply break loose once I get my car tuned (TONS of ignition timing advance, double digits certainly) or might hold because I launch off idle. When the track is colder like late at night, sometimes they break loose but only at higher RPMs unless I fudge the launch. Pretty wierd breaking them loose at 30-35 mph, then I shift into second (slowly, in my post tranny killing traumatic state) and everything's fine.
Old Aug 1, 2005 | 08:51 PM
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by JClaw
It will be interesting to see if they simply break loose once I get my car tuned (TONS of ignition timing advance, double digits certainly) or might hold because I launch off idle. When the track is colder like late at night, sometimes they break loose but only at higher RPMs unless I fudge the launch. Pretty wierd breaking them loose at 30-35 mph.
Yeah, I wouldn't count on them holding worth a crap on a cold night with a cold track with that extra power. The most my 60 foots have ever varied is 2 hundredths of a second. You need a consistant launch in order to have consistant 1/4 mile ETs. I just can't think of any way that you can tune down your car and make it slower other than a throttle stop or decreasing the HP by retarding timing, restricting exhaust or intake flow, etc.
Old Aug 2, 2005 | 03:44 AM
96sleeper's Avatar
My best ever is a 2.14. I think Veetec is the one who ran a 2.09, and that was when he was stock.
Old Aug 2, 2005 | 05:15 AM
max723's Avatar
you say you launch at idle? do you have an auto or 5 spd. im thinking of going to a track soonfor the 1st time. whats the best way to launch my 5 spd on street tires.
Old Aug 2, 2005 | 05:21 AM
Blu's Avatar
Blu
the tits
awesome 60's the best I could ever manage on my 18's was 2.11. 3.5L torque pwns.
Old Aug 2, 2005 | 05:27 AM
JClaw's Avatar
I have a 5-speed, but my idle is at 1500 rpm because of the VQ35 swap.
Old Aug 2, 2005 | 04:11 PM
Nealoc187's Avatar
SLOW
vqdriver hit 2.08 or 2.09 back in the day when he ran his 14.05
Old Aug 2, 2005 | 11:43 PM
I30tMikeD's Avatar
PB is 2.14 launching off idle. This was on 205/60/15 all seasons
Old Aug 3, 2005 | 03:44 AM
96sleeper's Avatar
I just noticed his car for sale in the for sale forum, if anyone needs a good one.
Old Aug 3, 2005 | 04:54 PM
Nealoc187's Avatar
SLOW
Wow I didn't know he was selling it. I used to talk to him on AIM all the time but I haven't seen him on in a couple months. He always asked me if he should sell it and I kept telling him to keep it.
Old Aug 14, 2005 | 10:30 AM
JClaw's Avatar
Beat my PB 60 foot again last night in the final round of eliminations (but had to hit the brakes afterwards). 2.033 with the Yokohamas. I did it only once though. Mostly 2.10's as usual.
Same setup as last time, except with more tie-wraps (10-12 on each spring) and a different setting for the traction bars. 23-24 psi front, 43 psi rear. The burnout really seems to help.
Old Aug 17, 2005 | 05:23 PM
doublea's Avatar
Good jobs man, that was in Napierville right ? I'll go next spring when my car is finish and see what kind of numbers I can pull.
Cheers
Old Aug 17, 2005 | 05:27 PM
JClaw's Avatar
Yep, fairly good track when they actually put some glue.
Old Aug 17, 2005 | 05:43 PM
doublea's Avatar
I'd be willing to test your bar on my modded 2k1 before I put her to sleep in october.
Let me know if that is any interest to you.
Cheers
Old Aug 17, 2005 | 10:21 PM
JClaw's Avatar
traction bars
Hi,
About the bars: The only way they will fit on a 2k1 is if you drill a 1" hole through the control arms. 4th gen control arms already have that big 1" hole, which I use as a mounting point. There is a hole there on 5th gen control arms, but it's much smaller, you'll have to drill it out to 1".If you could do that, it would most certainly fit.
Old Aug 18, 2005 | 04:58 AM
doublea's Avatar
Ok I'll take a look at this over the week-end and let you know shortly.
Old Aug 19, 2005 | 03:37 PM
Requin6's Avatar
yeah i hit 2.096 once and that was on my best pass of 12.9.
i havent been able to get anything near high 2.0's since.
Old Aug 19, 2005 | 03:40 PM
JClaw's Avatar
Track prep has a lot to do with it. On Tuesday nights (Rice festival) they don't put any glue and the track is cold as hell. Best I ever got on a Tuesday is 2.18 on street tires. On weekends when they actually prep the track, the launches are much more consistant.
Old Aug 19, 2005 | 09:49 PM
SR20DEN's Avatar
VQ Wizard
That's Sofa King we Todd did. Just think of the number of cars today that can break that right off the showroom floor.
Maybe you should put on a super quiet exhaust and run full interior with a bag of groceries in the trunk. And strap in a child saftey seat, to exemplify how dumb that rule is.
Old Aug 20, 2005 | 01:27 PM
JClaw's Avatar
Yeah, I could have 4 passengers and three dead bodies in the trunk, and still run a high 13. How about a "baby on board" sign too?
alahjahwan09
18
Sep 21, 2015 09:12 PM
RWCreative
Sep 21, 2015 11:01 AM
Serotta33
Sep 17, 2015 12:14 PM
Bonka
Sep 14, 2015 11:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
