1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
3000-3500 rpm idle for the track - bad?
Old Mar 3, 2006 | 12:42 PM
JClaw's Avatar
This is going to sound truly retarded but I know I've already talked about looking for a way to reduce drivetrain shock on launch. Would it cause any damage to run a 3000-3500 rpm idle for the track only?
Basically I'd just raise it up at the track only and put it back down to normal when leaving.
Reason I'd do this is to basically launch like an automatic. I'd sit at the line with the 3-3.5k idle and just release the clutch/floor it vs. straight dumping the clutch at 4-6k like I did last year (hard on the axles). It would also be good for consistancy & ET Bracket racing (Exactly the same launch RPM on every single run).
Thoughts? I would think it would act basically like a 3-3.5k converter on an auto.
Last time at the track I experimented @ regular idle (1400 rpms) and was able to pull a 1.93 60' on the 23-inch slicks launching at that rpm.
Old Mar 3, 2006 | 01:16 PM
Nismo3112's Avatar
Custom User Title
Hook up your IACV, it will make it idle at 3300-3500 rpm
Atleast that's what happend to me. I solved that problem by taking the IACV off.
Old Mar 3, 2006 | 01:28 PM
DandyMax's Avatar
3.5 in the works
Or you could use the 2-step on the EU...
Then again are you still planning on getting one if your OBDI project works out?
Old Mar 3, 2006 | 02:39 PM
JClaw's Avatar
If it doesn't work yeah I'll get the EU.
But do you guys think it'll hurt anything rolling around in the pits and sitting at the line with a 3000-3500 idle?
I'm just gonna have make an adjustable bracket for the cable so I can adjust it at the track. Throttle response is going to be ridiculous (Excellent for good reaction times).
Old Mar 5, 2006 | 05:42 AM
s0ber's Avatar
just push the car around and when u finally get to stage turn it on so ur not at 3000-3500 the whole time.
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 10, 2015 09:35 PM
