1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Manual fan switch
Old Apr 4, 2006 | 03:22 PM
ajcool2's Avatar
Manual fan switch
I'm want to do this mod and cannot find clear instructions on how to do it. I've been searching and found Jimes instructions but I still cant figure it out. I really need to do this before I go to the track sunday. I am not that good at wiring things so any help would be extremely helpful. If I could get a picture of how it is wired that would be great. THANK YOU!
Old Apr 4, 2006 | 06:13 PM
ajcool2's Avatar
Anybody? I think I may put everything back together and try tomorrow.
Old Apr 4, 2006 | 08:02 PM
NmexMAX's Avatar
dot dot dot ...
Cooler t-stat > fan mod...
Jimes walk through is quite ....ummm... "User friendly".... try again...
Old Apr 4, 2006 | 08:48 PM
JClaw's Avatar
I did this mod last spring.
1-Find the right wire running out of your ECU in Jime's instructions (I believe it is light green with a red stripe).
2-Run a simple wire from it to one of your driver seat bolt (what I used to ground it, you can use anything you want, the entire chassis serves as a ground).
3-Put a simple switch on that wire.
That's it. When you flip the switch, that wire is grounded, so your fan starts. It's as simple as that. I did it one random morning before going to the track.
Old Apr 4, 2006 | 09:02 PM
ajcool2's Avatar
Thank you sssoooo much! I will try this at lunch tomorrow. I almost messed some stuff up tonight its a good thing I stopped and waited for a responce.
Old Apr 4, 2006 | 09:04 PM
ajcool2's Avatar
I read a little bit on the thermostat mod yestarday. I'm going to research it more.
Old Apr 6, 2006 | 06:58 PM
chillin014's Avatar
i have not heard of a "cooler thermostat" mod. where is that?
and as far as the manual fan switch, thats a pretty tight little area to be soldering and cutting wires so if your not good at it, you should just take your time and work very slowly.
i used a knife to gently scrape off the plastic outter "skin" on the wire enough to loop my wire in there and make a connection, then soldered. simple concept though.
Old Apr 6, 2006 | 07:46 PM
NmexMAX's Avatar
dot dot dot ...
That's because you haven't ponied up the dough to search...
http://www.forums.maxima.org/showthread.php?t=215989
Old Apr 6, 2006 | 08:27 PM
chillin014's Avatar
thank you.
Old Apr 10, 2006 | 06:43 PM
ajcool2's Avatar
Does anybody know if this will work on a 2nd Gen?
Old Apr 10, 2006 | 06:58 PM
NmexMAX's Avatar
dot dot dot ...
If had a 2nd gen I would probably know.
Old Apr 11, 2006 | 09:02 PM
DJ Technischer's Avatar
Well if i could find the 88 ecu diagram , that would be a charm....
Old Apr 12, 2006 | 05:49 AM
TAPOUT's Avatar
You will lose
There should only be maybe 3 wires going to the fan. Constant, ground, trigger.
Old Apr 12, 2006 | 10:02 PM
Ohh , Well there is 2 blues , And one wire that is red ontop of white, Witch should i tap into?
Old Apr 13, 2006 | 08:58 PM
Heres mine :
Wonder how i would hook it up :|
Old Apr 13, 2006 | 08:59 PM
the 2 blue and black that are all togeather go to the fans , How do you think i could hook it up?
Old Apr 15, 2006 | 05:32 PM
Never mind i did it my self , It looks cool in the dark , And cools down the engine fast!!! , I ran the car for like 30 mins cruzin around local back roads dident take it out on main roads because i had no hood and no tags....
Pictures :
The ugly :
The awsome :
Old Apr 15, 2006 | 05:34 PM
Thats the temp set up till i get a switch box or some thing to mount under the dash.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
